跳转到主内容
ASUS Eee PC 1018P RAM Replacement
你所需要的
  1. ASUS Eee PC 1018P RAM Replacement, Battery: 步骤 1 中的图像 1,1
    • Lay the laptop flat on a hard surface with the bottom facing up and the battery pack on the side closest to you.
  2. ASUS Eee PC 1018P RAM Replacement: 步骤 2 中的图像 1,2 ASUS Eee PC 1018P RAM Replacement: 步骤 2 中的图像 2,2
    • Use both index fingers to push both spring tabs inwards towards the center of the laptop.
  3. ASUS Eee PC 1018P RAM Replacement: 步骤 3 中的图像 1,3 ASUS Eee PC 1018P RAM Replacement: 步骤 3 中的图像 2,3 ASUS Eee PC 1018P RAM Replacement: 步骤 3 中的图像 3,3
    • With the spring tabs pressed inward, use your fingernails to lift of the edge of the battery, pivoting it up and towards you.
    • Pull the battery pack up and away from you to completely free it from its recess in the case.
  4. ASUS Eee PC 1018P RAM Replacement, RAM: 步骤 4 中的图像 1,1
    • With the battery removed, locate the RAM cover.
  5. ASUS Eee PC 1018P RAM Replacement: 步骤 5 中的图像 1,2 ASUS Eee PC 1018P RAM Replacement: 步骤 5 中的图像 2,2
    • Use your thumb to pry up the exposed edge of the RAM cover. Once this edge is lifted, the cover will come free.
    • With the RAM cover removed, carefully peel back the silver foil that protects the RAM.
  6. ASUS Eee PC 1018P RAM Replacement: 步骤 6 中的图像 1,2 ASUS Eee PC 1018P RAM Replacement: 步骤 6 中的图像 2,2
    • Use the plastic opening tool to push aside the two silver tabs that hold down the RAM module.
    • In order to detach the tabs , use the plastic opening tool to pull the tab slightly toward the battery pack, then push outward away from the RAM module.
    • The RAM module will pop upward at a slight angle when both tabs are detached.
  7. ASUS Eee PC 1018P RAM Replacement: 步骤 7 中的图像 1,2 ASUS Eee PC 1018P RAM Replacement: 步骤 7 中的图像 2,2
    • Carefully grasping the edges of the RAM module, slowly pull it free from the pin connectors underneath the edge of the foil.
    • Pull the RAM out at the same angle that it pops up naturally to. Ripping the RAM free at other angles can damage the fragile pins.
  8. ASUS Eee PC 1018P RAM Replacement: 步骤 8 中的图像 1,1
    • Remove RAM module entirely for repair or replacement.
结论
另外一个人完成了本指南。
团队
Cal Poly, Team 8-13, Maness Winter 2012 Cal Poly, Team 8-13, Maness Winter 2012 的会员
CPSU-MANESS-W12S8G13
4 名成员
创作了11篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 10
总计 3,291
