跳转到主内容
ASUS Eee PC 1018P Keyboard Replacement
你所需要的
  1. ASUS Eee PC 1018P Keyboard Replacement, Battery: 步骤 1 中的图像 1,1
    • Lay the laptop flat on a hard surface with the bottom facing up and the battery pack on the side closest to you.
  2. ASUS Eee PC 1018P Keyboard Replacement: 步骤 2 中的图像 1,2 ASUS Eee PC 1018P Keyboard Replacement: 步骤 2 中的图像 2,2
    • Use both index fingers to push both spring tabs inwards towards the center of the laptop.
  3. ASUS Eee PC 1018P Keyboard Replacement: 步骤 3 中的图像 1,3 ASUS Eee PC 1018P Keyboard Replacement: 步骤 3 中的图像 2,3 ASUS Eee PC 1018P Keyboard Replacement: 步骤 3 中的图像 3,3
    • With the spring tabs pressed inward, use your fingernails to lift of the edge of the battery, pivoting it up and towards you.
    • Pull the battery pack up and away from you to completely free it from its recess in the case.
  4. ASUS Eee PC 1018P Keyboard Replacement, Keyboard: 步骤 4 中的图像 1,1
    • Remove the screws securing the bottom case to the keyboard.
    • Remove the six 3.68 mm screws and the single 4.45 mm screw that had been concealed by the battery.
    • Use a pair of tweezers to remove the two rubber covers located at the upper left and right corners.
    • With the rubber covers gone, two 4.52 mm screws should now be visible. Remove these screws.
  5. ASUS Eee PC 1018P Keyboard Replacement: 步骤 5 中的图像 1,2 ASUS Eee PC 1018P Keyboard Replacement: 步骤 5 中的图像 2,2
    • Pry the cover free from the chasis by inserting the plastic opening tool between the keyboard and the lower body of the Asus Eee PC 1018P.
    • Prying a keyboard from a laptop requires a lot of force, but the keyboard also has fragile connectors underneath. Use caution so as to avoid breaking these connectors.
  6. ASUS Eee PC 1018P Keyboard Replacement: 步骤 6 中的图像 1,1
    • Lift the outside edge of the keyboard upward and inward towards the screen. (See warning below.)
    • Take care not to lift the keyboard too high from the motherboard, as this may sever the ribbon cables that are still attached.
  7. ASUS Eee PC 1018P Keyboard Replacement: 步骤 7 中的图像 1,3 ASUS Eee PC 1018P Keyboard Replacement: 步骤 7 中的图像 2,3 ASUS Eee PC 1018P Keyboard Replacement: 步骤 7 中的图像 3,3
    • Remove the black ribbon cable from the motherboard.
    • Use the tip of the plastic opening tool to push the black tabs on both sides of the white connector forward toward the display.
    • Pushing forward on one side will push the other side back toward the touch pad. Repeat the previous step until both black tabs will not move any farther.
    • Carefully pull the black ribbon cable horizontally toward the display until it slides free from the white motherboard connector. If it does not move when pulling on it, repeat previous steps until it does.
  8. ASUS Eee PC 1018P Keyboard Replacement: 步骤 8 中的图像 1,3 ASUS Eee PC 1018P Keyboard Replacement: 步骤 8 中的图像 2,3 ASUS Eee PC 1018P Keyboard Replacement: 步骤 8 中的图像 3,3
    • Remove the white ribbon cable from the motherboard.
    • Insert the plastic opening tool under the small lip of the white ribbon connector, and pry upwards to pop the motherboard connector up.
    • Carefully remove the white ribbon cable by pulling it horizontally towards the touch pad.
  9. ASUS Eee PC 1018P Keyboard Replacement: 步骤 9 中的图像 1,1
    • The keyboard is now fully disconnected and can now be removed from the main body of the Asus Eee PC 1018P.
结论
另外一个人完成了本指南。
Michael
于01/20/12注册
43 声望
撰写一个指南
团队
Cal Poly, Team 8-13, Maness Winter 2012 Cal Poly, Team 8-13, Maness Winter 2012 的会员
CPSU-MANESS-W12S8G13
4 名成员
创作了11篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 4,780
