跳转到主内容
ASUS Eee PC 1001PX Disassembly To Fix Dead Black Screen
你所需要的
  1. ASUS Eee PC 1001PX Disassembly To Fix Dead Black Screen, Remove battery and RAM: 步骤 1 中的图像 1,2 ASUS Eee PC 1001PX Disassembly To Fix Dead Black Screen, Remove battery and RAM: 步骤 1 中的图像 2,2
    • Remove the external battery after pulling the unlock buttons outward.
    • Open the lid at the center and remove the RAM module by pulling the enclosing sides outward.
    • Remove the screw in the bottom-right corner.
  2. ASUS Eee PC 1001PX Disassembly To Fix Dead Black Screen, Remove Keyboard: 步骤 2 中的图像 1,2 ASUS Eee PC 1001PX Disassembly To Fix Dead Black Screen, Remove Keyboard: 步骤 2 中的图像 2,2
    • Remove the keyboard using a bit with a flat head or something like a bank card. Start from the left and then continue towards the right prying it open. Be extra-careful to not damage the keyboard.
  3. ASUS Eee PC 1001PX Disassembly To Fix Dead Black Screen, Disconnect Keyboard and Touchpad cables: 步骤 3 中的图像 1,3 ASUS Eee PC 1001PX Disassembly To Fix Dead Black Screen, Disconnect Keyboard and Touchpad cables: 步骤 3 中的图像 2,3 ASUS Eee PC 1001PX Disassembly To Fix Dead Black Screen, Disconnect Keyboard and Touchpad cables: 步骤 3 中的图像 3,3
    • Disconnect the black flexible flat cable by using the tip of a spudger or your fingernail.
    • Do the same with the touchbap blue cable to the left.
  4. ASUS Eee PC 1001PX Disassembly To Fix Dead Black Screen, Remove the palm rest assembly: 步骤 4 中的图像 1,3 ASUS Eee PC 1001PX Disassembly To Fix Dead Black Screen, Remove the palm rest assembly: 步骤 4 中的图像 2,3 ASUS Eee PC 1001PX Disassembly To Fix Dead Black Screen, Remove the palm rest assembly: 步骤 4 中的图像 3,3
    • Remove all the circled screws in the base panel.
    • Use a spudger or an opening pick to pry it open. Start from one of the two sides and then follow the laptop perimeter.
  5. ASUS Eee PC 1001PX Disassembly To Fix Dead Black Screen, Reset the CMOS battery: 步骤 5 中的图像 1,2 ASUS Eee PC 1001PX Disassembly To Fix Dead Black Screen, Reset the CMOS battery: 步骤 5 中的图像 2,2
    • Disconnect the red and black wires of the CMOS battery and leave it so for at least 1 minute (it depends on accumulated charge) before reconnecting it.
    • Draining the battery will cause the CMOS memory to lose the last persisted BIOS settings.
结论
Once done, reconnect the wires and follow the previous steps in reverse order.
Restarting the PC now, you should see the typical POST/splash screen.
另外一个人完成了本指南。
Giuliano Panzironi
于12/28/19注册
121 声望
撰写一个指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 34
总计 425
