跳转到主内容
ASUS E210MA-TB.CL464BK Battery Replacement
你所需要的
  1. ASUS E210MA-TB.CL464BK Battery Replacement, Battery: 步骤 1 中的图像 1,3 ASUS E210MA-TB.CL464BK Battery Replacement, Battery: 步骤 1 中的图像 2,3 ASUS E210MA-TB.CL464BK Battery Replacement, Battery: 步骤 1 中的图像 3,3
    • Place the laptop with the bottom side facing up. Have the front (where the mousepad is) facing toward you.
    • Start by removing the ten 7mm screws on the bottom of the laptop using a JIS #00 JIS screwdriver.
  2. ASUS E210MA-TB.CL464BK Battery Replacement: 步骤 2 中的图像 1,1
    • Double-check to make sure all of the screws are removed.
    • If you have a Jimmy or other flat, straight-edge object, slide it in the crack where the halves of the case meet.
    • When the parts are separated, pull them apart to expose the insides of the case.
  3. ASUS E210MA-TB.CL464BK Battery Replacement: 步骤 3 中的图像 1,2 ASUS E210MA-TB.CL464BK Battery Replacement: 步骤 3 中的图像 2,2
    • Remove the 4 mm screws around the USB port.
  4. ASUS E210MA-TB.CL464BK Battery Replacement: 步骤 4 中的图像 1,2 ASUS E210MA-TB.CL464BK Battery Replacement: 步骤 4 中的图像 2,2
    • Remove the 3 mm screws around the battery.
    • Carefully lift up the USB port and set it to the side.
  5. ASUS E210MA-TB.CL464BK Battery Replacement: 步骤 5 中的图像 1,2 ASUS E210MA-TB.CL464BK Battery Replacement: 步骤 5 中的图像 2,2
    • Unplug the connection between the motherboard and the battery by pulling towards the speaker side.
    • Repeat the same process to remove the blue tape on the second picture.
  6. ASUS E210MA-TB.CL464BK Battery Replacement: 步骤 6 中的图像 1,1
    • Lift up and remove the battery.
结论
John Hutchins
于02/07/23注册
763 声望
创作了5篇指南
团队
Gateway, Team 73-6, Gonzalez Spring 2023 Gateway, Team 73-6, Gonzalez Spring 2023 的会员
GCC-GONZALEZ-S23S73G6
5 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 13
过去 30 天: 44
总计 503
