简介
This is the ASUS Chromebook (Model C424MA-DH48F), here we will be guiding you though a daughterboard replacement for the ASUS Chromebook.
Alternatively called a piggyback board and daughter card, a daughterboard is an expansion board that connects directly to the motherboard and gives added functionality.
Reasons to replace the daughterboard include:
- Performance loss
- Sudden crashing
- Water damage
- Physical damage
你所需要的
Use a Phillips #0 screwdriver to remove the eleven 6.9 mm screws that secure the lower case.
Insert an opening pick into the gap between the lower case and chassis.
Slide the pick around the entire perimeter of the laptop until the lower case fully releases.
Remove the lower case.
Use an opening tool to pop up the silver locking bar securing the battery connector.
Push the battery connector directly out of its motherboard port.
Remove the thermal tape covering the large ribbon cable connector from the daughterboard.
Remove the black electrical tape from the small I/O connector on the bottom right corner of the daughterboard.
