跳转到主内容
ASUS Chromebook C300MA-DH01 Audio Speakers Replacement
你所需要的
  1. ASUS Chromebook C300MA-DH01 Audio Speakers Replacement, Audio Speakers: 步骤 1 中的图像 1,1
    • Flip the Chromebook over so the bottom of the device is facing up.
  2. ASUS Chromebook C300MA-DH01 Audio Speakers Replacement: 步骤 2 中的图像 1,2 ASUS Chromebook C300MA-DH01 Audio Speakers Replacement: 步骤 2 中的图像 2,2
    • Using the JIS-J0 Screwdriver, remove the following screws from the bottom:
    • (5) Five 6mm screws
    • (6) Six 8mm screws
  3. ASUS Chromebook C300MA-DH01 Audio Speakers Replacement: 步骤 3 中的图像 1,3 ASUS Chromebook C300MA-DH01 Audio Speakers Replacement: 步骤 3 中的图像 2,3 ASUS Chromebook C300MA-DH01 Audio Speakers Replacement: 步骤 3 中的图像 3,3
    • Gently wedge the spudger in between the bottom of the device and the keyboard, and carefully pry the cover open. Then, carefully lift up on keyboard.
  4. ASUS Chromebook C300MA-DH01 Audio Speakers Replacement: 步骤 4 中的图像 1,3 ASUS Chromebook C300MA-DH01 Audio Speakers Replacement: 步骤 4 中的图像 2,3 ASUS Chromebook C300MA-DH01 Audio Speakers Replacement: 步骤 4 中的图像 3,3
    • Gently detach connecting cables
    • Carefully flip up the large black tab.
    • Carefully flip up the small white tab.
    • Remove its corresponding black cable.
    • Remove the corresponding white cable.
    • The keyboard will be fully detached at this point.
  5. ASUS Chromebook C300MA-DH01 Audio Speakers Replacement: 步骤 5 中的图像 1,2 ASUS Chromebook C300MA-DH01 Audio Speakers Replacement: 步骤 5 中的图像 2,2
    • Using the JIS-J0 screwdriver, unscrew and remove from the battery:
    • (6) Six 6mm screws
  6. ASUS Chromebook C300MA-DH01 Audio Speakers Replacement: 步骤 6 中的图像 1,1
    • Using the plastic opening tool, gently push the connector tab away from the battery to detach the cable.
    • The battery will be fully detached at this point. Carefully lift it out of the device.
  7. ASUS Chromebook C300MA-DH01 Audio Speakers Replacement: 步骤 7 中的图像 1,2 ASUS Chromebook C300MA-DH01 Audio Speakers Replacement: 步骤 7 中的图像 2,2
    • Using the plastic opening tool, disconnect the audio connector by pushing the audio tab toward the speakers.
    • With the audio cable detached, carefully lift the speakers out of the device.
结论
Gina Altimari
于09/28/17注册
401 声望
创作了4篇指南
团队
USF Tampa, Team S2-G5, Passmore Fall 2017 USF Tampa, Team S2-G5, Passmore Fall 2017 的会员
USFT-PASSMORE-F17S2G5
3 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 142
