跳转到主内容
ASUS Chromebook C200MA DS01 Speaker Replacement
你所需要的
  1. ASUS Chromebook C200MA DS01 Speaker Replacement, Back Panel: 步骤 1 中的图像 1,1
    • Before proceeding, power down your Chromebook. Close the display and lay it on a soft surface, top-side down.
    • Remove the five 8.4 mm Phillips #0 screws.
    • Remove the four 4.6 mm Phillips #0 screws.
  2. ASUS Chromebook C200MA DS01 Speaker Replacement: 步骤 2 中的图像 1,1
    • Use the plastic opening tool to gently work around the edge of the Chromebook until the back panel starts to lift off.
  3. ASUS Chromebook C200MA DS01 Speaker Replacement: 步骤 3 中的图像 1,1
    • Remove the back panel by lifting it away from the Chromebook.
    • Some clicking will be heard as the panel is removed from the back, this is completely normal.
  4. ASUS Chromebook C200MA DS01 Speaker Replacement, Battery Connection: 步骤 4 中的图像 1,3 ASUS Chromebook C200MA DS01 Speaker Replacement, Battery Connection: 步骤 4 中的图像 2,3 ASUS Chromebook C200MA DS01 Speaker Replacement, Battery Connection: 步骤 4 中的图像 3,3
    • To disconnect the battery, pinch the multi-color bundle cable with your thumb and forefinger and pull directly back.
  5. ASUS Chromebook C200MA DS01 Speaker Replacement, Battery: 步骤 5 中的图像 1,2 ASUS Chromebook C200MA DS01 Speaker Replacement, Battery: 步骤 5 中的图像 2,2
    • Remove the four 4.7 mm Phillips #0 screws that secure the battery to the Chromebook.
  6. ASUS Chromebook C200MA DS01 Speaker Replacement: 步骤 6 中的图像 1,1
    • Pull out the battery.
  7. ASUS Chromebook C200MA DS01 Speaker Replacement, Speaker: 步骤 7 中的图像 1,2 ASUS Chromebook C200MA DS01 Speaker Replacement, Speaker: 步骤 7 中的图像 2,2
    • Disconnect the speaker's black bundled cable connector on the motherboard.
    • The cables are red, white and black.
    • Pinch the black bundled cable connector between your thumb and pointer finger and pull.
  8. ASUS Chromebook C200MA DS01 Speaker Replacement: 步骤 8 中的图像 1,2 ASUS Chromebook C200MA DS01 Speaker Replacement: 步骤 8 中的图像 2,2
    • Using your hands or the small plastic opening tool, pry the right speaker from the Chromebook.
    • There are small adhesives under the speakers that will provide moderate resistance.
  9. ASUS Chromebook C200MA DS01 Speaker Replacement: 步骤 9 中的图像 1,2 ASUS Chromebook C200MA DS01 Speaker Replacement: 步骤 9 中的图像 2,2
    • Disconnect the USB port ZIF(zero insertion force) connector that partially covers the left speaker.
    • Flip the ZIF retaining flap up using a spudger or your fingers.
    • Pull gently on the ribbon cable to remove it from the connector.
  10. ASUS Chromebook C200MA DS01 Speaker Replacement: 步骤 10 中的图像 1,2 ASUS Chromebook C200MA DS01 Speaker Replacement: 步骤 10 中的图像 2,2
    • Unravel the connecting cord between the two speakers.
  11. ASUS Chromebook C200MA DS01 Speaker Replacement: 步骤 11 中的图像 1,3 ASUS Chromebook C200MA DS01 Speaker Replacement: 步骤 11 中的图像 2,3 ASUS Chromebook C200MA DS01 Speaker Replacement: 步骤 11 中的图像 3,3
    • Using the small plastic opening tool, pry the left speaker from the Chromebook.
    • Remove the speakers.
    • There are small adhesives that will provide moderate resistance.
结论
Christopher Lim
于04/26/17注册
779 声望
创作了7篇指南
团队
Cal Poly, Team S23-G4, Livingston Spring 2017 Cal Poly, Team S23-G4, Livingston Spring 2017 的会员
CPSU-LIVINGSTON-S17S23G4
4 名成员
创作了19篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 17
总计 297
