跳转到主内容
ASUS Chromebook C100PA-RBRKT07 Battery Replacement
你所需要的
  1. ASUS Chromebook C100PA-RBRKT07 Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Use the T5 screwdriver to remove the nine 2.1 mm screws from the bottom of the device.
  2. ASUS Chromebook C100PA-RBRKT07 Battery Replacement: 步骤 2 中的图像 1,1
    • Use the iFixit opening tool to remove the 4 pads to reveal six 3.1 mm screws underneath.
  3. ASUS Chromebook C100PA-RBRKT07 Battery Replacement: 步骤 3 中的图像 1,1
    • Use the T5 screwdriver to remove the 6 3.1 mm screws under the pads.
    • There might be a layer of tape that covers the screws. Remove the tape first with a pair of tweezers.
  4. ASUS Chromebook C100PA-RBRKT07 Battery Replacement: 步骤 4 中的图像 1,1
    • Use the iFixit opening tool to pry the backing of the device off.
  5. ASUS Chromebook C100PA-RBRKT07 Battery Replacement: 步骤 5 中的图像 1,1
    • Use the tweezers to separate the cables from the motherboard.
    • You need to reach inside and peel some tape to disconnect the wire.
  6. ASUS Chromebook C100PA-RBRKT07 Battery Replacement: 步骤 6 中的图像 1,1
    • Use the JIS1 screwdriver to remove the four 2.1 mm screws around the audio cards.
  7. ASUS Chromebook C100PA-RBRKT07 Battery Replacement: 步骤 7 中的图像 1,2 ASUS Chromebook C100PA-RBRKT07 Battery Replacement: 步骤 7 中的图像 2,2
    • Gently disconnect the audio cards, exposing the battery.
  8. ASUS Chromebook C100PA-RBRKT07 Battery Replacement: 步骤 8 中的图像 1,1
    • Use the J00 screwdriver to remove the three 1.7 mm battery screws.
  9. ASUS Chromebook C100PA-RBRKT07 Battery Replacement: 步骤 9 中的图像 1,3 ASUS Chromebook C100PA-RBRKT07 Battery Replacement: 步骤 9 中的图像 2,3 ASUS Chromebook C100PA-RBRKT07 Battery Replacement: 步骤 9 中的图像 3,3
    • Grip the battery and remove it from the device.
    • Remove the battery cable out of the motherboard by lifting the battery cables.
结论
Tiffany Foo
于01/24/19注册
289 声望
创作了2篇指南
团队
Cal Poly, Team S19-G4, White Winter 2019 Cal Poly, Team S19-G4, White Winter 2019 的会员
CPSU-WHITE-W19S19G4
4 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 8
总计 370
