跳转到主内容
ASUS X540BA-BB61-CB Screen Replacement
你所需要的
  1. ASUS  X540BA-BB61-CB Screen Replacement, Power Down the Laptop: 步骤 1 中的图像 1,2 ASUS  X540BA-BB61-CB Screen Replacement, Power Down the Laptop: 步骤 1 中的图像 2,2
    • Power off the device and unplug it from the charging cord.
  2. ASUS  X540BA-BB61-CB Screen Replacement, Remove the Bezel Frame: 步骤 2 中的图像 1,2 ASUS  X540BA-BB61-CB Screen Replacement, Remove the Bezel Frame: 步骤 2 中的图像 2,2
    • Use a spudger to remove the plastic screw covers in the bottom right and left corner of the screen.
    • Remove the two Phillips #2 (M2.5 x4)mm flat head screws in the two bottom corners under the screw covers.
    • Then remove the bezel frame with a spudger.
  3. ASUS  X540BA-BB61-CB Screen Replacement, Remove the Bezel: 步骤 3 中的图像 1,1
    • Once these screws are removed, carefully remove the bezel by the inner edge working your way around the perimeter.
    • Be careful to undo the clips as you remove the bezel and don't yank it off. The bezel is flexible but can break.
  4. ASUS  X540BA-BB61-CB Screen Replacement, Remove the grounding tape: 步骤 4 中的图像 1,1
    • Remove the grounding tape covering the screws in the four corners of the screen.
    • Use a Phillips #2 screwdriver to remove four (M2 x 4) mm screws from the four corners of the screen that hold the LCD panel in place.
  5. ASUS  X540BA-BB61-CB Screen Replacement, Remove the Screen: 步骤 5 中的图像 1,1
    • Peel off one side of the tape and remove the two bottom screws.
    • It is important to remember that the video cable is secured with cleared tape.
    • Peel off the tape, gently slide the cable out and remove the LCD Panel. Take the new LCD panel and place it on the keyboard.
    • Gently slide the connector to the jack secured with cleared tape with both hands.
结论
David Shodipo
于01/14/22注册
1 声望
撰写一个指南
团队
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 17
过去 30 天: 69
总计 2,519
