跳转到主内容
Aroma ARC-914SBD Lid Replacement
你所需要的
  1. Aroma ARC-914SBD Lid Replacement, Lid: 步骤 1 中的图像 1,2 Aroma ARC-914SBD Lid Replacement, Lid: 步骤 1 中的图像 2,2
    • The first step is removing the condensation catcher in order to reach the control panel. We do this by pinching the condensation catcher as shown, on both sides and pull the condensation catcher away from the cooker.
  2. Aroma ARC-914SBD Lid Replacement: 步骤 2 中的图像 1,1
    • Once the condensation catcher has been removed, set it aside for reassembly later.
    • Now make sure you have a a Phillips head screwdriver, size PH2. This tool will allow you to remove the screw that was behind the condensation catcher.
  3. Aroma ARC-914SBD Lid Replacement: 步骤 3 中的图像 1,2 Aroma ARC-914SBD Lid Replacement: 步骤 3 中的图像 2,2
    • Gently remove the piece that was held in place by the screw, you do this by pulling out from the top, then pulling up. This will expose the hinges for the lid.
  4. Aroma ARC-914SBD Lid Replacement: 步骤 4 中的图像 1,3 Aroma ARC-914SBD Lid Replacement: 步骤 4 中的图像 2,3 Aroma ARC-914SBD Lid Replacement: 步骤 4 中的图像 3,3
    • To remove the hinge, gently rotate the bottom of the rod upwards, then push inward to pull the rod out. Repeat the process for each rod. This will allow the lid to be removed.
结论
另外一个人完成了本指南。
Brandon Nieves
于09/04/15注册
956 声望
创作了8篇指南
团队
USF Tampa, Team 2-3, Sullivan Fall 2015 USF Tampa, Team 2-3, Sullivan Fall 2015 的会员
USFT-SULLIVAN-F15S2G3
3 名成员
创作了8篇指南
一条评论
Where can you buy a replacement lid?
Cristian Ortiz - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 16
过去 30 天: 37
总计 2,153
