跳转到主内容
APS Tech 101629 SCSI Connections Replacement
你所需要的
  1. APS Tech 101629 SCSI Connections Replacement, External Casing: 步骤 1 中的图像 1,3 APS Tech 101629 SCSI Connections Replacement, External Casing: 步骤 1 中的图像 2,3 APS Tech 101629 SCSI Connections Replacement, External Casing: 步骤 1 中的图像 3,3
    • Pry all four of the plastic feet off the bottom of the enclosure using the iPod opening tool.
  2. APS Tech 101629 SCSI Connections Replacement: 步骤 2 中的图像 1,2 APS Tech 101629 SCSI Connections Replacement: 步骤 2 中的图像 2,2
    • Unscrew the four screws previously covered by the feet with a Phillips #1 screwdriver.
  3. APS Tech 101629 SCSI Connections Replacement: 步骤 3 中的图像 1,2 APS Tech 101629 SCSI Connections Replacement: 步骤 3 中的图像 2,2
    • Flip the device right side up.
    • Gently slide the casing upwards and off the hard drive.
  4. APS Tech 101629 SCSI Connections Replacement: 步骤 4 中的图像 1,1
    • Flip device upside down again.
    • Gently pry the bottom gray casing away from the device.
  5. APS Tech 101629 SCSI Connections Replacement: 步骤 5 中的图像 1,2 APS Tech 101629 SCSI Connections Replacement: 步骤 5 中的图像 2,2
    • Rotate so the back of the device is facing you.
    • Gently pry the back casing away.
    • When the back casing is removed, the fan will become loose.
  6. APS Tech 101629 SCSI Connections Replacement, Internal Drive Component: 步骤 6 中的图像 1,2 APS Tech 101629 SCSI Connections Replacement, Internal Drive Component: 步骤 6 中的图像 2,2
    • Flip so device is upside down.
    • Remove 4 screws with Phillips #1 screw driver.
    • Be sure to save the washers that seperate the screws from the baseplate for reassembly.
  7. APS Tech 101629 SCSI Connections Replacement: 步骤 7 中的图像 1,2 APS Tech 101629 SCSI Connections Replacement: 步骤 7 中的图像 2,2
    • Slide the internal drive component away from the back of the device.
    • Remove the connections from the back of the internal component in the order of your choosing, we suggest left to right. The connections are:
    • Audio Connection
    • SCSI ID
    • Terminate On
    • SCSI Connection
    • DC Input (power)
  8. APS Tech 101629 SCSI Connections Replacement, SCSI Connections: 步骤 8 中的图像 1,3 APS Tech 101629 SCSI Connections Replacement, SCSI Connections: 步骤 8 中的图像 2,3 APS Tech 101629 SCSI Connections Replacement, SCSI Connections: 步骤 8 中的图像 3,3
    • Remove the four Phillips #1 Screws from back panel.
    • Once the screws are removed, the two connections are easily removed from the body.
结论
Patrick Meyer
于04/10/11注册
83 声望
创作了3篇指南
团队
Cal Poly, Team 24-60, Amido Spring 2011 Cal Poly, Team 24-60, Amido Spring 2011 的会员
CPSU-AMIDO-S11S24G60
5 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 8
总计 888
