跳转到主内容
加入维修社区 - 创建账户
APS Tech 101629 Power Switch Replacement
你所需要的
  1. APS Tech 101629 Power Switch Replacement, External Casing: 步骤 1 中的图像 1,3 APS Tech 101629 Power Switch Replacement, External Casing: 步骤 1 中的图像 2,3 APS Tech 101629 Power Switch Replacement, External Casing: 步骤 1 中的图像 3,3
    • Pry all four of the plastic feet off the bottom of the enclosure using the iPod opening tool.
    询问修复机器人
    添加评论
  2. APS Tech 101629 Power Switch Replacement: 步骤 2 中的图像 1,2 APS Tech 101629 Power Switch Replacement: 步骤 2 中的图像 2,2
    • Unscrew the four screws previously covered by the feet with a Phillips #1 screwdriver.
    询问修复机器人
    添加评论
  3. APS Tech 101629 Power Switch Replacement: 步骤 3 中的图像 1,2 APS Tech 101629 Power Switch Replacement: 步骤 3 中的图像 2,2
    • Flip the device right side up.
    • Gently slide the casing upwards and off the hard drive.
    询问修复机器人
    添加评论
  4. APS Tech 101629 Power Switch Replacement: 步骤 4 中的图像 1,1
    • Flip device upside down again.
    • Gently pry the bottom gray casing away from the device.
    询问修复机器人
    添加评论
  5. APS Tech 101629 Power Switch Replacement: 步骤 5 中的图像 1,2 APS Tech 101629 Power Switch Replacement: 步骤 5 中的图像 2,2
    • Rotate so the back of the device is facing you.
    • Gently pry the back casing away.
    • When the back casing is removed, the fan will become loose.
    询问修复机器人
    添加评论
  6. APS Tech 101629 Power Switch Replacement, Channel Switch: 步骤 6 中的图像 1,2 APS Tech 101629 Power Switch Replacement, Channel Switch: 步骤 6 中的图像 2,2
    • Find the conjoined ID cable wires that are colored black, orange, and yellow.
    • Lift white portion of cable wires to disconnect it.
    询问修复机器人
    添加评论
  7. APS Tech 101629 Power Switch Replacement: 步骤 7 中的图像 1,3 APS Tech 101629 Power Switch Replacement: 步骤 7 中的图像 2,3 APS Tech 101629 Power Switch Replacement: 步骤 7 中的图像 3,3
    • At this point, the fan is loose and can be easily moved but not disconnected.
    • Using the spudger, depress the pressure holders at all four corners of the fan.
    • Take out the fan and its cords, by pulling it outward from its cavity within the device.
    询问修复机器人
    添加评论
  8. APS Tech 101629 Power Switch Replacement, Power Switch: 步骤 8 中的图像 1,2 APS Tech 101629 Power Switch Replacement, Power Switch: 步骤 8 中的图像 2,2
    • Depress 2 pressure holds on each side of the power switch.
    • Press out the back of the device.
    询问修复机器人
    添加评论
  9. APS Tech 101629 Power Switch Replacement: 步骤 9 中的图像 1,2 APS Tech 101629 Power Switch Replacement: 步骤 9 中的图像 2,2
    • Remove all four 4 connections from the power switch.
    • Remember that the straight connections are on the far side, while the L-shaped connections are on the near side, and that both yellow connections are on top. This is helpful for reassembly.
    • These are very hard to get off, use patience and wiggling.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
Alexis Weckel
于04/11/11注册
140 声望
创作了3篇指南
团队
Cal Poly, Team 24-60, Amido Spring 2011 Cal Poly, Team 24-60, Amido Spring 2011 的会员
CPSU-AMIDO-S11S24G60
5 名成员
创作了12篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 42
总计 1,014
