跳转到主内容
加入维修社区 - 创建账户
APS Tech 101629 Internal Drive Component Replacement
你所需要的
  1. APS Tech 101629 Internal Drive Component Replacement, External Casing: 步骤 1 中的图像 1,3 APS Tech 101629 Internal Drive Component Replacement, External Casing: 步骤 1 中的图像 2,3 APS Tech 101629 Internal Drive Component Replacement, External Casing: 步骤 1 中的图像 3,3
    • Pry all four of the plastic feet off the bottom of the enclosure using the iPod opening tool.
    询问修复机器人
    添加评论
  2. APS Tech 101629 Internal Drive Component Replacement: 步骤 2 中的图像 1,2 APS Tech 101629 Internal Drive Component Replacement: 步骤 2 中的图像 2,2
    • Unscrew the four screws previously covered by the feet with a Phillips #1 screwdriver.
    询问修复机器人
    添加评论
  3. APS Tech 101629 Internal Drive Component Replacement: 步骤 3 中的图像 1,2 APS Tech 101629 Internal Drive Component Replacement: 步骤 3 中的图像 2,2
    • Flip the device right side up.
    • Gently slide the casing upwards and off the hard drive.
    询问修复机器人
    添加评论
  4. APS Tech 101629 Internal Drive Component Replacement: 步骤 4 中的图像 1,1
    • Flip device upside down again.
    • Gently pry the bottom gray casing away from the device.
    询问修复机器人
    添加评论
  5. APS Tech 101629 Internal Drive Component Replacement: 步骤 5 中的图像 1,2 APS Tech 101629 Internal Drive Component Replacement: 步骤 5 中的图像 2,2
    • Rotate so the back of the device is facing you.
    • Gently pry the back casing away.
    • When the back casing is removed, the fan will become loose.
    询问修复机器人
    添加评论
  6. APS Tech 101629 Internal Drive Component Replacement, Internal Drive Component: 步骤 6 中的图像 1,2 APS Tech 101629 Internal Drive Component Replacement, Internal Drive Component: 步骤 6 中的图像 2,2
    • Flip so device is upside down.
    • Remove 4 screws with Phillips #1 screw driver.
    • Be sure to save the washers that seperate the screws from the baseplate for reassembly.
    询问修复机器人
    添加评论
  7. APS Tech 101629 Internal Drive Component Replacement: 步骤 7 中的图像 1,2 APS Tech 101629 Internal Drive Component Replacement: 步骤 7 中的图像 2,2
    • Slide the internal drive component away from the back of the device.
    • Remove the connections from the back of the internal component in the order of your choosing, we suggest left to right. The connections are:
    • Audio Connection
    • SCSI ID
    • Terminate On
    • SCSI Connection
    • DC Input (power)
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
2等其他人完成本指南。
Alexis Weckel
于04/11/11注册
140 声望
创作了3篇指南
团队
Cal Poly, Team 24-60, Amido Spring 2011 Cal Poly, Team 24-60, Amido Spring 2011 的会员
CPSU-AMIDO-S11S24G60
5 名成员
创作了12篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 38
总计 1,522
