跳转到主内容
APS Tech 101629 Channel Switch Replacement
你所需要的
  1. APS Tech 101629 Channel Switch Replacement, External Casing: 步骤 1 中的图像 1,3 APS Tech 101629 Channel Switch Replacement, External Casing: 步骤 1 中的图像 2,3 APS Tech 101629 Channel Switch Replacement, External Casing: 步骤 1 中的图像 3,3
    • Pry all four of the plastic feet off the bottom of the enclosure using the iPod opening tool.
  2. APS Tech 101629 Channel Switch Replacement: 步骤 2 中的图像 1,2 APS Tech 101629 Channel Switch Replacement: 步骤 2 中的图像 2,2
    • Unscrew the four screws previously covered by the feet with a Phillips #1 screwdriver.
  3. APS Tech 101629 Channel Switch Replacement: 步骤 3 中的图像 1,2 APS Tech 101629 Channel Switch Replacement: 步骤 3 中的图像 2,2
    • Flip the device right side up.
    • Gently slide the casing upwards and off the hard drive.
  4. APS Tech 101629 Channel Switch Replacement: 步骤 4 中的图像 1,1
    • Flip device upside down again.
    • Gently pry the bottom gray casing away from the device.
  5. APS Tech 101629 Channel Switch Replacement: 步骤 5 中的图像 1,2 APS Tech 101629 Channel Switch Replacement: 步骤 5 中的图像 2,2
    • Rotate so the back of the device is facing you.
    • Gently pry the back casing away.
    • When the back casing is removed, the fan will become loose.
  6. APS Tech 101629 Channel Switch Replacement, Channel Switch: 步骤 6 中的图像 1,2 APS Tech 101629 Channel Switch Replacement, Channel Switch: 步骤 6 中的图像 2,2
    • Find the conjoined ID cable wires that are colored black, orange, and yellow.
    • Lift white portion of cable wires to disconnect it.
  7. APS Tech 101629 Channel Switch Replacement: 步骤 7 中的图像 1,3 APS Tech 101629 Channel Switch Replacement: 步骤 7 中的图像 2,3 APS Tech 101629 Channel Switch Replacement: 步骤 7 中的图像 3,3
    • At this point, the fan is loose and can be easily moved but not disconnected.
    • Using the spudger, depress the pressure holders at all four corners of the fan.
    • Take out the fan and its cords, by pulling it outward from its cavity within the device.
结论
另外一个人完成了本指南。
Alexis Weckel
于04/11/11注册
140 声望
创作了3篇指南
团队
Cal Poly, Team 24-60, Amido Spring 2011 Cal Poly, Team 24-60, Amido Spring 2011 的会员
CPSU-AMIDO-S11S24G60
5 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 651
