简介
The guide is written to replace the device's battery if the battery does not hold a charge well or does not function at all.
You will need an opening tool for removing the cover and a soldering kit for removing the wires.
Caution: Never puncture or excessively bend the battery during removal. This can cause extreme heat and possible injury.
For your safety, discharge your battery below 25% before disassembling your phone. This reduces the risk of a dangerous thermal event if the battery is accidentally damaged during the repair.
你所需要的
Start by bending the tablet back at the top white-colored portion to expose an opening between the back cover and the tablet body.
Wedge a plastic opening tool into the opening and push it down to force the back cover off.
Move along the top edge of the tablet and repeat the step above.
Pull the back cover away from the tablet body to completely remove it.
With the back cover removed, you can now see the battery.
You will need a soldering/desoldering kit to desolder the 3 battery leads to the circuit board.
2等其他人完成本指南。
