跳转到主内容
APEX AP-GS918 Power/Volume Button Replacement
你所需要的
  1. APEX AP-GS918 Power/Volume Button Replacement, Power/Volume Button: 步骤 1 中的图像 1,3 APEX AP-GS918 Power/Volume Button Replacement, Power/Volume Button: 步骤 1 中的图像 2,3 APEX AP-GS918 Power/Volume Button Replacement, Power/Volume Button: 步骤 1 中的图像 3,3
    • To begin, locate the two 4.9mm Phillips #00 screws at the top corners of the case and remove them.
  2. APEX AP-GS918 Power/Volume Button Replacement: 步骤 2 中的图像 1,3 APEX AP-GS918 Power/Volume Button Replacement: 步骤 2 中的图像 2,3 APEX AP-GS918 Power/Volume Button Replacement: 步骤 2 中的图像 3,3
    • Squeeze the plastic opening tool in between the seam where the screen joins the plastic case.
    • Begin separating the bottom of the case from the screen by carefully going around the whole edge of the case and slowly prying it apart.
    • Be careful when separating the lids because the wires holding the speaker to the motherboard are very short.
  3. APEX AP-GS918 Power/Volume Button Replacement: 步骤 3 中的图像 1,2 APEX AP-GS918 Power/Volume Button Replacement: 步骤 3 中的图像 2,2
    在这个步骤中使用的工具:
    • Carefully place the bottom lid next to the screen case. The power/speaker buttons should be visible at the corner of the lid. Remove the buttons with the tweezers.
结论
团队
USF Tampa, Team 9-1, Leahy Winter 2015 USF Tampa, Team 9-1, Leahy Winter 2015 的会员
USFT-LEAHY-W15S9G1
3 名成员
创作了9篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 304
