跳转到主内容
APEX AP-GS918 Camera Replacement
你所需要的
  1. APEX AP-GS918 Camera Replacement, Power/Volume Button: 步骤 1 中的图像 1,3 APEX AP-GS918 Camera Replacement, Power/Volume Button: 步骤 1 中的图像 2,3 APEX AP-GS918 Camera Replacement, Power/Volume Button: 步骤 1 中的图像 3,3
    • To begin, locate the two 4.9mm Phillips #00 screws at the top corners of the case and remove them.
  2. APEX AP-GS918 Camera Replacement: 步骤 2 中的图像 1,3 APEX AP-GS918 Camera Replacement: 步骤 2 中的图像 2,3 APEX AP-GS918 Camera Replacement: 步骤 2 中的图像 3,3
    • Squeeze the plastic opening tool in between the seam where the screen joins the plastic case.
    • Begin separating the bottom of the case from the screen by carefully going around the whole edge of the case and slowly prying it apart.
    • Be careful when separating the lids because the wires holding the speaker to the motherboard are very short.
  3. APEX AP-GS918 Camera Replacement: 步骤 3 中的图像 1,2 APEX AP-GS918 Camera Replacement: 步骤 3 中的图像 2,2
    在这个步骤中使用的工具:
    • Carefully place the bottom lid next to the screen case. The power/speaker buttons should be visible at the corner of the lid. Remove the buttons with the tweezers.
  4. APEX AP-GS918 Camera Replacement, Camera: 步骤 4 中的图像 1,3 APEX AP-GS918 Camera Replacement, Camera: 步骤 4 中的图像 2,3 APEX AP-GS918 Camera Replacement, Camera: 步骤 4 中的图像 3,3
    • Remove the black electrical tape covering the motherboard components along with the black cloth tape covering the camera itself.
    • Be careful when removing the black cloth tape from the camera on the top left corner of the tablet. The tape will likely stick and pull the camera with it.
  5. APEX AP-GS918 Camera Replacement: 步骤 5 中的图像 1,3 APEX AP-GS918 Camera Replacement: 步骤 5 中的图像 2,3 APEX AP-GS918 Camera Replacement: 步骤 5 中的图像 3,3
    • Locate the white and gray connector that's holding the camera in place.
    • Use the black nylon spudger to eject the camera from its slot by gently lifting the gray clip vertically 90°.
    • Once ejected, you may easily remove the camera by pulling it from its slot.
结论
Megan Lozicki
于02/19/15注册
416 声望
创作了4篇指南
团队
USF Tampa, Team 9-1, Leahy Winter 2015 USF Tampa, Team 9-1, Leahy Winter 2015 的会员
USFT-LEAHY-W15S9G1
3 名成员
创作了9篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 13
总计 358
