跳转到主内容
APEX AP-GS918 Battery Replacement
你所需要的
  1. APEX AP-GS918 Battery Replacement, Power/Volume Button: 步骤 1 中的图像 1,3 APEX AP-GS918 Battery Replacement, Power/Volume Button: 步骤 1 中的图像 2,3 APEX AP-GS918 Battery Replacement, Power/Volume Button: 步骤 1 中的图像 3,3
    • To begin, locate the two 4.9mm Phillips #00 screws at the top corners of the case and remove them.
  2. APEX AP-GS918 Battery Replacement: 步骤 2 中的图像 1,3 APEX AP-GS918 Battery Replacement: 步骤 2 中的图像 2,3 APEX AP-GS918 Battery Replacement: 步骤 2 中的图像 3,3
    • Squeeze the plastic opening tool in between the seam where the screen joins the plastic case.
    • Begin separating the bottom of the case from the screen by carefully going around the whole edge of the case and slowly prying it apart.
    • Be careful when separating the lids because the wires holding the speaker to the motherboard are very short.
  3. APEX AP-GS918 Battery Replacement: 步骤 3 中的图像 1,2 APEX AP-GS918 Battery Replacement: 步骤 3 中的图像 2,2
    在这个步骤中使用的工具:
    • Carefully place the bottom lid next to the screen case. The power/speaker buttons should be visible at the corner of the lid. Remove the buttons with the tweezers.
  4. APEX AP-GS918 Battery Replacement, Battery: 步骤 4 中的图像 1,2 APEX AP-GS918 Battery Replacement, Battery: 步骤 4 中的图像 2,2
    • Begin removing the black tape covering the motherboard inside the tablet.
  5. APEX AP-GS918 Battery Replacement: 步骤 5 中的图像 1,1
    • You will need to desolder the two contact points that connect the battery to the mother board.
    • Make sure to allow ample time (at least 5-8 minutes or more) for the soldering iron to heat up. Otherwise, the solder won't melt.
    • Touch the hot iron to the contact points and gently pull on the wires to loosen them from the solder. They should release easily.
    • Make sure not to touch the contact points after desoldering them because they will remain very hot for a short while afterwards.
  6. APEX AP-GS918 Battery Replacement: 步骤 6 中的图像 1,2 APEX AP-GS918 Battery Replacement: 步骤 6 中的图像 2,2
    • Using the black nylon spudger, get underneath the battery and begin prying it loose from the rest of the tablet.
    • The tape holding the battery to the tablet has a very strong hold so be prepared for resistance.
结论
3等其他人完成本指南。
Megan Lozicki
于02/19/15注册
416 声望
创作了4篇指南
团队
USF Tampa, Team 9-1, Leahy Winter 2015 USF Tampa, Team 9-1, Leahy Winter 2015 的会员
USFT-LEAHY-W15S9G1
3 名成员
创作了9篇指南
1指南评论
bien consejo, creo que es sencillo por todos para seguin estos pasos
harkhoscole - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 20
总计 673
