跳转到主内容
AORUS 590X M.2 SSD Replacement
你所需要的
  1. AORUS 590X M.2 SSD Replacement, M.2 SSD: 步骤 1 中的图像 1,2 AORUS 590X M.2 SSD Replacement, M.2 SSD: 步骤 1 中的图像 2,2
    • Switch off your computer and unplug the power supply cord.
    • Different PC towers have various outlays for disassembly and reassembly purposes. This guide will demonstrate a general procedure.
    • Refer to your specific computer tower guides for disassembly purposes on the iFixit community or other online resources.
  2. AORUS 590X M.2 SSD Replacement: 步骤 2 中的图像 1,3 AORUS 590X M.2 SSD Replacement: 步骤 2 中的图像 2,3 AORUS 590X M.2 SSD Replacement: 步骤 2 中的图像 3,3
    • Unplug any additional ports that are still plugged in.
    • Take a Phillips #0 screwdriver and remove two top panel screws.
  3. AORUS 590X M.2 SSD Replacement: 步骤 3 中的图像 1,3 AORUS 590X M.2 SSD Replacement: 步骤 3 中的图像 2,3 AORUS 590X M.2 SSD Replacement: 步骤 3 中的图像 3,3
    • Press down the latch pin and pull the top tower cover towards yourself at the same time.
    • When the latch pins are disconnected, slide the cover upwards towards the ceiling.
    • Do not immediately pull upwards, this will bend and damage the pins for reassembly purposes.
  4. AORUS 590X M.2 SSD Replacement: 步骤 4 中的图像 1,3 AORUS 590X M.2 SSD Replacement: 步骤 4 中的图像 2,3 AORUS 590X M.2 SSD Replacement: 步骤 4 中的图像 3,3
    • Use both hands to gently grab the top and bottom portion of the glass side panel. Then pull upward towards the ceiling to remove the panel.
    • When removing glass from a modern high end PC, make sure to distribute pressure away from resistance (pins, latches, and tabs).
    • Most steel and metal computers will follow this general procedure.
  5. AORUS 590X M.2 SSD Replacement: 步骤 5 中的图像 1,3 AORUS 590X M.2 SSD Replacement: 步骤 5 中的图像 2,3 AORUS 590X M.2 SSD Replacement: 步骤 5 中的图像 3,3
    • Tilt the computer tower using both hands to lay the tower horizontally flat to get a complete view of the motherboard.
    • Locate the SSD slot labelled M.2. The slots will on the center to bottom portion of the motherboard.
  6. AORUS 590X M.2 SSD Replacement: 步骤 6 中的图像 1,2 AORUS 590X M.2 SSD Replacement: 步骤 6 中的图像 2,2
    • Before working on the motherboard component, make sure to clip an anti static wristband to the computer tower to ground yourself.
    • In the case you do not have ESD or anti static discharge equipment, make sure to touch a metal object before proceeding into further steps. This will reduce chances of you unintentionally frying your motherboard.
  7. AORUS 590X M.2 SSD Replacement: 步骤 7 中的图像 1,3 AORUS 590X M.2 SSD Replacement: 步骤 7 中的图像 2,3 AORUS 590X M.2 SSD Replacement: 步骤 7 中的图像 3,3
    • Unscrew the opposite end of the M.2 cover and gently pull diagonally to reveal the SSD slot.
  8. AORUS 590X M.2 SSD Replacement: 步骤 8 中的图像 1,3 AORUS 590X M.2 SSD Replacement: 步骤 8 中的图像 2,3 AORUS 590X M.2 SSD Replacement: 步骤 8 中的图像 3,3
    • Once you have removed the cover, you should see three silver screw mounts. Your SSD size will align correctly to the appropriate length hole.
    • Align the M.2 SSD pin with the correct connector slot and gently push in.
    • The M.2 port has a specific pin shape to correctly align the SSD.
  9. AORUS 590X M.2 SSD Replacement: 步骤 9 中的图像 1,2 AORUS 590X M.2 SSD Replacement: 步骤 9 中的图像 2,2
    • Use the computer supplied (2.0 x 3.0 mm) Phillips #0 screws to secure the SSD in place.
    • The M.2 SSD is now installed. You can reassemble your tower or mount the motherboard onto the PC now. Further steps is to insure the SSD is covered from dust.
  10. AORUS 590X M.2 SSD Replacement: 步骤 10 中的图像 1,3 AORUS 590X M.2 SSD Replacement: 步骤 10 中的图像 2,3 AORUS 590X M.2 SSD Replacement: 步骤 10 中的图像 3,3
    • Peel off the plastic film on the underside of the M.2 dust cover to reveal the adhesive.
    • Place the dust cover end edges first into the area label M.2. Then slowly press down throughout the cover ensuring adhesive contact.
    • Do not place the adhesive in the center or on the SSD first. This can cause complication aligning it correctly.
    • The plastic film may get stuck in chucks. Do not use finger nails or sharp objects to pick at the film. The adhesive cover is soft and spongy. Use a blow dryer to soften the adhesive then grab it gently pulling towards yourself.
  11. AORUS 590X M.2 SSD Replacement: 步骤 11 中的图像 1,2 AORUS 590X M.2 SSD Replacement: 步骤 11 中的图像 2,2
    • Use the computer supplied (2.0 x 3.0 mm) Phillips #0 screw to secure the SSD dust cover.
结论
To reassemble your device, follow these instructions in reverse order. These steps will vary if you are dissembling your own computer.
3等其他人完成本指南。
Johnny Doan
于05/06/20注册
280 声望
撰写一个指南
团队
UW Tacoma, Team S1-G33, Cardinal Spring 2020 UW Tacoma, Team S1-G33, Cardinal Spring 2020 的会员
UWT-CARDINAL-S20S1G33
1 名成员
创作了1篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 6
总计 251
