跳转到主内容
AKASO KingPad A90 Volume Rocker/Power Button Unit Replacement
你所需要的
  1. AKASO KingPad A90 Volume Rocker/Power Button Unit Replacement, Volume Rocker/Power Button Unit: 步骤 1 中的图像 1,3 AKASO KingPad A90 Volume Rocker/Power Button Unit Replacement, Volume Rocker/Power Button Unit: 步骤 1 中的图像 2,3 AKASO KingPad A90 Volume Rocker/Power Button Unit Replacement, Volume Rocker/Power Button Unit: 步骤 1 中的图像 3,3
    • Remove screws
    • Insert spudger tool on the middle of the left side, between the white and black plastic
    • Slide in a plastic opening tool and use it to further pull the back off.
    • Work your way around the edge of the tablet with the plastic opening tool and insert more as needed
    • Pull off the back cover
  2. AKASO KingPad A90 Volume Rocker/Power Button Unit Replacement: 步骤 2 中的图像 1,3 AKASO KingPad A90 Volume Rocker/Power Button Unit Replacement: 步骤 2 中的图像 2,3 AKASO KingPad A90 Volume Rocker/Power Button Unit Replacement: 步骤 2 中的图像 3,3
    • Remove the broken volume rocker/power button unit.
    • Place the new part into the empty slot.
  3. AKASO KingPad A90 Volume Rocker/Power Button Unit Replacement: 步骤 3 中的图像 1,3 AKASO KingPad A90 Volume Rocker/Power Button Unit Replacement: 步骤 3 中的图像 2,3 AKASO KingPad A90 Volume Rocker/Power Button Unit Replacement: 步骤 3 中的图像 3,3
    • Gently press the speaker into place.
    • Replace the back cover with the new part in place.
    • Be careful to not let the volume rocker unit fall out of place.
    • Replace the screws.
终点
2等其他人完成本指南。
Miles
于03/24/15注册
260 声望
创作了2篇指南
团队
UMass Dartmouth, Team 4-6, Vijaybhaskar Spring 2015 UMass Dartmouth, Team 4-6, Vijaybhaskar Spring 2015 的会员
UMASSD-VIJAYBHASKAR-S15S4G6
3 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 519
