跳转到主内容
AKASO KingPad A90 Rear Speaker Replacement
你所需要的
  1. AKASO KingPad A90 Rear Speaker Replacement, Rear Speaker: 步骤 1 中的图像 1,3 AKASO KingPad A90 Rear Speaker Replacement, Rear Speaker: 步骤 1 中的图像 2,3 AKASO KingPad A90 Rear Speaker Replacement, Rear Speaker: 步骤 1 中的图像 3,3
    • Remove screws.
    • Insert spudger tool on the middle of the left side, between the white and black plastic.
    • Slide in a plastic opening tool and use it to further pull the back off.
    • Work your way around the edge of the tablet with the plastic opening tool and insert more as needed.
    • Pull off the back cover.
  2. AKASO KingPad A90 Rear Speaker Replacement: 步骤 2 中的图像 1,3 AKASO KingPad A90 Rear Speaker Replacement: 步骤 2 中的图像 2,3 AKASO KingPad A90 Rear Speaker Replacement: 步骤 2 中的图像 3,3
    • Plug in soldering iron and let it warm up for ten minutes.
    • Locate the speaker solder points and note where it is attached to the motherboard.
    • Solder the old speaker out of its mark. (Touch the tip of the solder iron to the soldering point).
  3. AKASO KingPad A90 Rear Speaker Replacement: 步骤 3 中的图像 1,3 AKASO KingPad A90 Rear Speaker Replacement: 步骤 3 中的图像 2,3 AKASO KingPad A90 Rear Speaker Replacement: 步骤 3 中的图像 3,3
    • Solder the new speaker onto the points where the old speaker was.
  4. AKASO KingPad A90 Rear Speaker Replacement: 步骤 4 中的图像 1,3 AKASO KingPad A90 Rear Speaker Replacement: 步骤 4 中的图像 2,3 AKASO KingPad A90 Rear Speaker Replacement: 步骤 4 中的图像 3,3
    • Replace the back cover with the new rear speaker unit in place.
    • Gently press the speaker into place.
    • Don't let the volume rocker unit fall out of place.
    • Replace the screws.
终点
camchristo
于03/24/15注册
71 声望
撰写一个指南
团队
UMass Dartmouth, Team 4-6, Vijaybhaskar Spring 2015 UMass Dartmouth, Team 4-6, Vijaybhaskar Spring 2015 的会员
UMASSD-VIJAYBHASKAR-S15S4G6
3 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 8
总计 380
