跳转到主内容
AKASO KingPad A90 Camera (Rear and Front) Unit Replacement
你所需要的
  1. AKASO KingPad A90 Camera (Rear and Front) Unit Replacement, Camera (Rear and Front) Unit: 步骤 1 中的图像 1,3 AKASO KingPad A90 Camera (Rear and Front) Unit Replacement, Camera (Rear and Front) Unit: 步骤 1 中的图像 2,3 AKASO KingPad A90 Camera (Rear and Front) Unit Replacement, Camera (Rear and Front) Unit: 步骤 1 中的图像 3,3
    • Remove screws.
    • Insert spudger tool on the middle of the left side, between the white and black plastic.
    • Slide in a plastic opening tool and use it to further pull the back off.
    • Work your way around the edge of the tablet with the plastic opening tool and insert more as needed.
    • Pull off the back cover.
  2. AKASO KingPad A90 Camera (Rear and Front) Unit Replacement: 步骤 2 中的图像 1,3 AKASO KingPad A90 Camera (Rear and Front) Unit Replacement: 步骤 2 中的图像 2,3 AKASO KingPad A90 Camera (Rear and Front) Unit Replacement: 步骤 2 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Locate the camera unit and note where it is attached to the motherboard.
    • Grasp the camera unit with tweezers or fingers, and pull firmly to remove it from the adhesive holding it to the motherboard.
    • Be careful when lifting up the camera unit. Don’t tear the ribbon cable! Ensure that you examine the second picture of this step.
    • Using the spudger, carefully loosen the slot's plastic cover piece holding the ribbon cable in place.
    • Pull the ribbon cable out.
    • Remove the old adhesive with tweezers.
  3. AKASO KingPad A90 Camera (Rear and Front) Unit Replacement: 步骤 3 中的图像 1,3 AKASO KingPad A90 Camera (Rear and Front) Unit Replacement: 步骤 3 中的图像 2,3 AKASO KingPad A90 Camera (Rear and Front) Unit Replacement: 步骤 3 中的图像 3,3
    • Apply a small square of new adhesive in the same spot as the old adhesive was previously.
    • Gently slide the new camera unit's ribbon cable into the slot.
    • Give the ribbon a firm push to make sure it has made contact.
    • Press the plastic cover piece back in place with the spudger.
    • Firmly press the new camera onto the adhesive, making sure to line it up correctly.
  4. AKASO KingPad A90 Camera (Rear and Front) Unit Replacement: 步骤 4 中的图像 1,3 AKASO KingPad A90 Camera (Rear and Front) Unit Replacement: 步骤 4 中的图像 2,3 AKASO KingPad A90 Camera (Rear and Front) Unit Replacement: 步骤 4 中的图像 3,3
    • Replace the back cover with the new camera unit in place.
    • Gently press the speaker into place.
    • Don't let the volume rocker unit fall out of place.
    • Replace the screws.
终点
2等其他人完成本指南。
Miles
于03/24/15注册
260 声望
创作了2篇指南
团队
UMass Dartmouth, Team 4-6, Vijaybhaskar Spring 2015 UMass Dartmouth, Team 4-6, Vijaybhaskar Spring 2015 的会员
UMASSD-VIJAYBHASKAR-S15S4G6
3 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 11
总计 701
