简介
If the lever on your AFK 70372 toaster won't stay down but the element does get hot if you hold it down, this could be the result of several things. This guide shows you how to access and check the electromagnet, and replace it if required.
你所需要的
Make sure to unplug the toaster.
An electrical shock could occur if the toaster is not unplugged.
Remove any foreign objects that may be located inside the toaster. After all objects are removed, turn the toaster upside down.
Use a tri-wing screwdriver to remove the screws located on each corner.
Using the needle nose pliers, bend the two metal strips so they are facing the same direction.
Using the tweezers, pull out the long metal rod between the black casing and the metal component.
While pushing the casing and metal away from each other, bend the two metal strips which are contained by the platform outwards.
Once the spring is loose, remove it using the needle nose pliers.
Now that the electronic parts are clearly visible and easy to reach, the connections to the electromagnet can be unsoldered. Initially, only unsolder one of them.
With a testmeter on the resistance or Ω range, touch the two probes together and ensure the meter reads zero. Now touch one testmeter probe on the end of the now free electromagnet wire and the other on the other wire still soldered to the circuit board.
If you get infinite resistance then the electromagnet is faulty. Unsolder the other wire, remove the electromagnet by removing 2 screws, and replace.
If the electromagnet shows a resistance of a few hundred ohms then the fault lies elsewhere. Check the circuit board for any obviously overheated components, and if you are able, check there is a good connection to the circuit board from a tap on the element which taps off a small fraction of the mains voltage.
