跳转到主内容
AEG Electrolux FM72 Disassembly for cleaning
你所需要的
  1. AEG Electrolux FM72 Disassembly for cleaning, Opening the Device: 步骤 1 中的图像 1,3 AEG Electrolux FM72 Disassembly for cleaning, Opening the Device: 步骤 1 中的图像 2,3 AEG Electrolux FM72 Disassembly for cleaning, Opening the Device: 步骤 1 中的图像 3,3
    • Open the lid by pressing the grey button and lifting it away.
    • Clean each of the plastic parts with soap and water, and then leave them out to dry.
  2. AEG Electrolux FM72 Disassembly for cleaning, Opening the Electronic Case: 步骤 2 中的图像 1,3 AEG Electrolux FM72 Disassembly for cleaning, Opening the Electronic Case: 步骤 2 中的图像 2,3 AEG Electrolux FM72 Disassembly for cleaning, Opening the Electronic Case: 步骤 2 中的图像 3,3
    • Follow these steps to open the electronic casing.
    • Remove the four screws as shown in picture two.
    • A long Phillips screwdriver is needed for step two.
    • Remove the fifth screw at the bottom as shown in picture three.
  3. AEG Electrolux FM72 Disassembly for cleaning: 步骤 3 中的图像 1,3 AEG Electrolux FM72 Disassembly for cleaning: 步骤 3 中的图像 2,3 AEG Electrolux FM72 Disassembly for cleaning: 步骤 3 中的图像 3,3
    • Gently pry the device open, using an iSesamo opener.
    • Now the I/O button can be removed.
    • Completely replacing this entire part requires desoldering wire connections.
  4. AEG Electrolux FM72 Disassembly for cleaning, cleaning electronics: 步骤 4 中的图像 1,2 AEG Electrolux FM72 Disassembly for cleaning, cleaning electronics: 步骤 4 中的图像 2,2
    • Now the electronic components can be cleaned using an air compressor.
    • In picture one, you can see the PCBs. Under the PCB, you'll see blue batteries. These are 2 x 3 AA rechargeable batteries .
    • If the dust bag needs to be replaced, remove its securing screws.
结论
3等其他人完成本指南。
Kevin D
于05/02/14注册
7,343 声望
创作了21篇指南
3条评论
Hello
How can i repair the electric wire on this device please ?
Heloise - 回复
Hallo
Which electric wire do you mean? Can you send in a picture? Does it need soldering?
Kind regards
Kevin
Kevin D - 回复
How can I disassemble the motor parts for cleaning?
wongkapo0611 - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 35
总计 6,621
