跳转到主内容
本指南有最近更改,您可查看未经巡查的最新版本
AEE Mach 1 Camera Replacement
你所需要的
  1. AEE Mach 1 Camera Replacement, Camera: 步骤 1 中的图像 1,1
    • Take out the AEE Mach 1 and place it on a surface with its propellers facing up.
  2. AEE Mach 1 Camera Replacement: 步骤 2 中的图像 1,2 AEE Mach 1 Camera Replacement: 步骤 2 中的图像 2,2
    • Holding the base of a propeller with one hand, unscrew the propeller by hand in a clockwise direction. Complete this action on all 4 propellers.
  3. AEE Mach 1 Camera Replacement: 步骤 3 中的图像 1,2 AEE Mach 1 Camera Replacement: 步骤 3 中的图像 2,2
    • Flip the AEE Mach 1 upside down.
    • Remove the screws on the drone's arms using a Torx T5 screwdriver.
  4. AEE Mach 1 Camera Replacement: 步骤 4 中的图像 1,2 AEE Mach 1 Camera Replacement: 步骤 4 中的图像 2,2
    • Gently pry open the top panel of the drone using a spudger.
    • Do not completely remove the panel, as there will still be wired connections between the two halves.
    • Rotate the top panel slightly to reveal the four screws beneath each propellor arm.
    • Remove each of the four screws with a Phillips #0 screwdriver.
    • Lift off the top panel, as it should now be free from the rest of the device.
  5. AEE Mach 1 Camera Replacement: 步骤 5 中的图像 1,1
    • Using a Phillips #00 screwdriver, remove the screws from the four corners of the inner white chassis.
  6. AEE Mach 1 Camera Replacement: 步骤 6 中的图像 1,2 AEE Mach 1 Camera Replacement: 步骤 6 中的图像 2,2
    • Using a Spudger (or similar tool to scrap/pry with), remove the copper foil used as tape from the sides of the chassis.
    • Remove the small metal covering from the side boards.
    • This can be done by hand or with the assistance of a prying tool.
  7. AEE Mach 1 Camera Replacement: 步骤 7 中的图像 1,2 AEE Mach 1 Camera Replacement: 步骤 7 中的图像 2,2
    • Using a Phillips #00 screwdriver, remove the four screws separating the side board from the white chassis.
  8. AEE Mach 1 Camera Replacement: 步骤 8 中的图像 1,2 AEE Mach 1 Camera Replacement: 步骤 8 中的图像 2,2
    • Using a Phillips #00 screwdriver, remove the four screws from the large motherboard on the white chassis.
    • Lift the motherboard out of the case, revealing the camera cable.
  9. AEE Mach 1 Camera Replacement: 步骤 9 中的图像 1,3 AEE Mach 1 Camera Replacement: 步骤 9 中的图像 2,3 AEE Mach 1 Camera Replacement: 步骤 9 中的图像 3,3
    • Using the Phillips #00 screwdriver, remove the four screws holding the camera mechanism in place.
    • Lift the camera assembly out of the case.
结论
团队
dwsad dwsad 的会员
Community
1 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 5
总计 250
