当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Make sure that your device is powered off before doing any work.
The battery is located at the back of the drone, on the opposite end of the drone from the camera.
There are two tabs on the edge of each side of the battery.
To remove the battery, simply grip the battery by the tabs, press down on both tabs, and pull the battery out.
To replace the battery, simply slide it back into its place until the tabs click back into place. If you are having trouble doing this, you may be putting it in upside down. Try flipping it over and trying again.
取消:我没有完成这个指南。
另外一个人完成了本指南。
与4其他贡献者
于09/04/19注册
382 声望
创作了2篇指南
徽章: 8
+ 5更多徽章
UA-BEDSOLE-F19S1G4
4 名成员
创作了3篇指南
purchase the aee mach 1 but it has no battery
Ulysses aka UL Salett - 2020年12月22日 回复
How do I get a new battery where do I look
haroldlknight55 - 2022年6月2日 回复
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 29
总计 638
