跳转到主内容
AEE Mach 1 Battery Replacement
  1. AEE Mach 1 Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Make sure that your device is powered off before doing any work.
    • The battery is located at the back of the drone, on the opposite end of the drone from the camera.
    • There are two tabs on the edge of each side of the battery.
  2. AEE Mach 1 Battery Replacement: 步骤 2 中的图像 1,1
    • To remove the battery, simply grip the battery by the tabs, press down on both tabs, and pull the battery out.
  3. AEE Mach 1 Battery Replacement: 步骤 3 中的图像 1,1
    • To replace the battery, simply slide it back into its place until the tabs click back into place. If you are having trouble doing this, you may be putting it in upside down. Try flipping it over and trying again.
结论
另外一个人完成了本指南。
2指南评论
purchase the aee mach 1 but it has no battery
Ulysses aka UL Salett - 回复
How do I get a new battery where do I look
haroldlknight55 - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 34
总计 1,208
