跳转到主内容
ACN Iris WG4K Video Camera Replacement
你所需要的
  1. ACN Iris WG4K Video Camera Replacement, Handset: 步骤 1 中的图像 1,2 ACN Iris WG4K Video Camera Replacement, Handset: 步骤 1 中的图像 2,2
    • Press upwards with your index finger on the 4P4C connector as shown in the image.
    • Pull the connector gently out of its socket.
  2. ACN Iris WG4K Video Camera Replacement, Lower Case: 步骤 2 中的图像 1,1
    • Flip the main body of the video phone so that the bottom is facing up.
    • Use the Phillips #0 Screwdriver to remove the four Phillips head screws (6 mm) highlighted by the red circles.
  3. ACN Iris WG4K Video Camera Replacement: 步骤 3 中的图像 1,2 ACN Iris WG4K Video Camera Replacement: 步骤 3 中的图像 2,2
    • Lift the back case upwards to expose the inside components.
    • Red rectangles indicate the three ribbon cables.
    • The orange square indicates the blade connector.
  4. ACN Iris WG4K Video Camera Replacement: 步骤 4 中的图像 1,3 ACN Iris WG4K Video Camera Replacement: 步骤 4 中的图像 2,3 ACN Iris WG4K Video Camera Replacement: 步骤 4 中的图像 3,3
    • Disconnect the three ribbon cables from their insulation-displacement connectors by flipping up the black plastic clip.
    • Gently pull the ribbon cables out of their insulation-displacement connectors.
  5. ACN Iris WG4K Video Camera Replacement: 步骤 5 中的图像 1,2 ACN Iris WG4K Video Camera Replacement: 步骤 5 中的图像 2,2
    • Disconnect the blade connector from the blade receptacle by gripping the exposed area of the blade connector.
    • Gently pull the blade connector out of the blade receptacle.
  6. ACN Iris WG4K Video Camera Replacement: 步骤 6 中的图像 1,1
    • Gently lift up the lower case to separate it from the top case.
  7. ACN Iris WG4K Video Camera Replacement, Blade Connector: 步骤 7 中的图像 1,1
  8. ACN Iris WG4K Video Camera Replacement: 步骤 8 中的图像 1,1
    • Gently lift up on the upper case to separate it from the keypad/speaker panel.
  9. ACN Iris WG4K Video Camera Replacement: 步骤 9 中的图像 1,1
    • Use the Phillips #0 Screwdriver to remove the two Phillips head screws (5 mm) located on the upper case.
  10. ACN Iris WG4K Video Camera Replacement: 步骤 10 中的图像 1,1
    • Rotate the top case 180 degrees so that the video screen is closest to you.
    • Lift up the bottom up so that it is perpendicular to the table (this helps you reach the two top screws).
    • The four Phillips head screws (6 mm) are highlighted by the red circles.
  11. ACN Iris WG4K Video Camera Replacement: 步骤 11 中的图像 1,1
    • Use the Phillips #0 Screwdriver to remove the four Phillips head screws (6 mm).
  12. ACN Iris WG4K Video Camera Replacement: 步骤 12 中的图像 1,1
    • Flip the top case so that the video screen is facing up.
  13. ACN Iris WG4K Video Camera Replacement: 步骤 13 中的图像 1,1
    • Rotate the top case 180 degrees.
    • Gently lift up on the video screen and the blade and ribbon connector to give you more slack to work with.
  14. ACN Iris WG4K Video Camera Replacement: 步骤 14 中的图像 1,1
    • Place the video screen face down to expose the two screws. The screws are indicated by the red circles.
  15. ACN Iris WG4K Video Camera Replacement: 步骤 15 中的图像 1,2 ACN Iris WG4K Video Camera Replacement: 步骤 15 中的图像 2,2
    • Use the Phillips #0 Screwdriver to remove the two Phillips head screws (6 mm)
  16. ACN Iris WG4K Video Camera Replacement: 步骤 16 中的图像 1,2 ACN Iris WG4K Video Camera Replacement: 步骤 16 中的图像 2,2
    • Pull the ribbon connector and blade connector through the top case.
  17. ACN Iris WG4K Video Camera Replacement, Video Screen Ribbon Cable: 步骤 17 中的图像 1,1
    • Note that the video screen is no longer attached to the top case, place in on a flat surface.
    • Gently lift of the silver casing.
  18. ACN Iris WG4K Video Camera Replacement: 步骤 18 中的图像 1,3 ACN Iris WG4K Video Camera Replacement: 步骤 18 中的图像 2,3 ACN Iris WG4K Video Camera Replacement: 步骤 18 中的图像 3,3
    • The two ribbon connectors are indicated by the red rectangles.
    • Disconnect the two ribbon cables from their insulation-displacement connectors by flipping up the black plastic clip.
    • Gently pull out the ribbon cables. Gently pull out the ribbon cables.
  19. ACN Iris WG4K Video Camera Replacement, Video Screen: 步骤 19 中的图像 1,1
    • Gently lift the video screen out of its case.
  20. ACN Iris WG4K Video Camera Replacement, Video Camera: 步骤 20 中的图像 1,3 ACN Iris WG4K Video Camera Replacement, Video Camera: 步骤 20 中的图像 2,3 ACN Iris WG4K Video Camera Replacement, Video Camera: 步骤 20 中的图像 3,3
    • Flip the video screen over so that the screen itself is face-down on a flat surface to expose the camera.
    • Push up on the two clips located on the right and left side of the video camera simultaneously.
    • Gently pull the camera out.
结论
Itze Kenney
于02/14/17注册
1,066 声望
创作了9篇指南
团队
USF Tampa, Team 20-4, Remmell Spring 2017 USF Tampa, Team 20-4, Remmell Spring 2017 的会员
USFT-REMMELL-S17S20G4
4 名成员
创作了20篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 7
总计 186
