跳转到主内容
ACN Iris WG4K Lower Case Replacement
你所需要的
  1. ACN Iris WG4K Lower Case Replacement, Handset: 步骤 1 中的图像 1,2 ACN Iris WG4K Lower Case Replacement, Handset: 步骤 1 中的图像 2,2
    • Press upwards with your index finger on the 4P4C connector as shown in the image.
    • Pull the connector gently out of its socket.
  2. ACN Iris WG4K Lower Case Replacement, Lower Case: 步骤 2 中的图像 1,1
    • Flip the main body of the video phone so that the bottom is facing up.
    • Use the Phillips #0 Screwdriver to remove the four Phillips head screws (6 mm) highlighted by the red circles.
  3. ACN Iris WG4K Lower Case Replacement: 步骤 3 中的图像 1,2 ACN Iris WG4K Lower Case Replacement: 步骤 3 中的图像 2,2
    • Lift the back case upwards to expose the inside components.
    • Red rectangles indicate the three ribbon cables.
    • The orange square indicates the blade connector.
  4. ACN Iris WG4K Lower Case Replacement: 步骤 4 中的图像 1,3 ACN Iris WG4K Lower Case Replacement: 步骤 4 中的图像 2,3 ACN Iris WG4K Lower Case Replacement: 步骤 4 中的图像 3,3
    • Disconnect the three ribbon cables from their insulation-displacement connectors by flipping up the black plastic clip.
    • Gently pull the ribbon cables out of their insulation-displacement connectors.
  5. ACN Iris WG4K Lower Case Replacement: 步骤 5 中的图像 1,2 ACN Iris WG4K Lower Case Replacement: 步骤 5 中的图像 2,2
    • Disconnect the blade connector from the blade receptacle by gripping the exposed area of the blade connector.
    • Gently pull the blade connector out of the blade receptacle.
  6. ACN Iris WG4K Lower Case Replacement: 步骤 6 中的图像 1,1
    • Gently lift up the lower case to separate it from the top case.
结论
另外一个人完成了本指南。
Itze Kenney
于02/14/17注册
1,066 声望
创作了9篇指南
团队
USF Tampa, Team 20-4, Remmell Spring 2017 USF Tampa, Team 20-4, Remmell Spring 2017 的会员
USFT-REMMELL-S17S20G4
4 名成员
创作了20篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 183
