跳转到主内容
ACER Aspire V5-571P-6609 Touchpad Replacement
你所需要的
  1. ACER Aspire V5-571P-6609 Touchpad Replacement, Touchpad: 步骤 1 中的图像 1,3 ACER Aspire V5-571P-6609 Touchpad Replacement, Touchpad: 步骤 1 中的图像 2,3 ACER Aspire V5-571P-6609 Touchpad Replacement, Touchpad: 步骤 1 中的图像 3,3
    • Close the laptop and flip over. Locate battery slide release. This guide marks the location with a red circle.
    • Use a pointed tool (we used a screwdriver) to slide release to the right when facing the laptop from the non-battery side.
    • Gently pull the battery away from the laptop with the slide release held open.
  2. ACER Aspire V5-571P-6609 Touchpad Replacement: 步骤 2 中的图像 1,1
    • Remove the two Phillips #0 screws.
    • Once all necessary screws are removed, turn the laptop over and open it.
  3. ACER Aspire V5-571P-6609 Touchpad Replacement: 步骤 3 中的图像 1,3 ACER Aspire V5-571P-6609 Touchpad Replacement: 步骤 3 中的图像 2,3 ACER Aspire V5-571P-6609 Touchpad Replacement: 步骤 3 中的图像 3,3
    • Slide a Jimmy tool between the top of the keyboard and the outer panel, then gently pop the top tabs out of place.
    • Carefully detach the two flex cables before fully lifting keyboard out in order to avoid cable damage.
    • Once cables are safely detached, lift the keyboard off of the laptop and place it on a safe, non-static surface.
  4. ACER Aspire V5-571P-6609 Touchpad Replacement: 步骤 4 中的图像 1,3 ACER Aspire V5-571P-6609 Touchpad Replacement: 步骤 4 中的图像 2,3 ACER Aspire V5-571P-6609 Touchpad Replacement: 步骤 4 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Remove the six Phillips #0 screws.
    • Flip up the plastic lock bar mechanism securing the two ribbon cables.
    • Gently pull the cables out of their ports with tweezers.
  5. ACER Aspire V5-571P-6609 Touchpad Replacement: 步骤 5 中的图像 1,3 ACER Aspire V5-571P-6609 Touchpad Replacement: 步骤 5 中的图像 2,3 ACER Aspire V5-571P-6609 Touchpad Replacement: 步骤 5 中的图像 3,3
    • Slide a Jimmy in between the front and back panel of the laptop
    • Slowly rotate the Jimmy tool in hand until the top panel pops loose. Repeat on all sides until the top panel is free of the main body.
    • Gently lift the top panel free of the main body.
  6. ACER Aspire V5-571P-6609 Touchpad Replacement: 步骤 6 中的图像 1,3 ACER Aspire V5-571P-6609 Touchpad Replacement: 步骤 6 中的图像 2,3 ACER Aspire V5-571P-6609 Touchpad Replacement: 步骤 6 中的图像 3,3
    • Flip the top panel over and locate the touchpad.
    • Flip up the connector's lock bar from the touchpad, then disconnect the cable.
    • Peel down the adhesive tape securing the touchpad and remove the three Phillips #0 screws securing the touchpad.
  7. ACER Aspire V5-571P-6609 Touchpad Replacement: 步骤 7 中的图像 1,3 ACER Aspire V5-571P-6609 Touchpad Replacement: 步骤 7 中的图像 2,3 ACER Aspire V5-571P-6609 Touchpad Replacement: 步骤 7 中的图像 3,3
    • Once screws have been removed, place fingers under and over the touchpad and slowly push it up; firmly hold the touchpad as it is being removed.
    • Replace the touch pad with a new touchpad.
结论
Ernesto Pacheco
于10/25/22注册
277 声望
创作了2篇指南
团队
Gateway, Team 1-1, Pee Fall 2022 Gateway, Team 1-1, Pee Fall 2022 的会员
GCC-PEE-F22S1G1
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 16
总计 181
