跳转到主内容
ACER Aspire V5-571P-6609 RAM Replacement
你所需要的
  1. ACER Aspire V5-571P-6609 RAM Replacement, RAM: 步骤 1 中的图像 1,3 ACER Aspire V5-571P-6609 RAM Replacement, RAM: 步骤 1 中的图像 2,3 ACER Aspire V5-571P-6609 RAM Replacement, RAM: 步骤 1 中的图像 3,3
    • Make sure you completely power off the device before proceeding.
    • Turn over the device to display the back cover and remove the two marked Phillips #0 screws.
  2. ACER Aspire V5-571P-6609 RAM Replacement: 步骤 2 中的图像 1,3 ACER Aspire V5-571P-6609 RAM Replacement: 步骤 2 中的图像 2,3 ACER Aspire V5-571P-6609 RAM Replacement: 步骤 2 中的图像 3,3
    • Once the screws have been removed, utilize a jimmy tool to pry open the back cover. Carefully lift the cover and set it aside for now.
  3. ACER Aspire V5-571P-6609 RAM Replacement: 步骤 3 中的图像 1,3 ACER Aspire V5-571P-6609 RAM Replacement: 步骤 3 中的图像 2,3 ACER Aspire V5-571P-6609 RAM Replacement: 步骤 3 中的图像 3,3
    • With two fingers, push the latches holding the DIMM to the sides.
    • The DIMM will tilt upward once it is released from the slot.
    • Carefully secure the DIMM and remove it.
  4. ACER Aspire V5-571P-6609 RAM Replacement: 步骤 4 中的图像 1,3 ACER Aspire V5-571P-6609 RAM Replacement: 步骤 4 中的图像 2,3 ACER Aspire V5-571P-6609 RAM Replacement: 步骤 4 中的图像 3,3
    • Repeat the same process from the previous step for the second slot.
  5. ACER Aspire V5-571P-6609 RAM Replacement: 步骤 5 中的图像 1,2 ACER Aspire V5-571P-6609 RAM Replacement: 步骤 5 中的图像 2,2
    • Insert the replacement DIMM into the slot.
    • Once inserted, push the DIMM down gently until it snaps into place.
  6. ACER Aspire V5-571P-6609 RAM Replacement: 步骤 6 中的图像 1,3 ACER Aspire V5-571P-6609 RAM Replacement: 步骤 6 中的图像 2,3 ACER Aspire V5-571P-6609 RAM Replacement: 步骤 6 中的图像 3,3
    • Place the cover back on.
    • Insert the screws back into place with a screwdriver.
结论
To reassemble your device, follow these instructions in reverse order with new RAM cards.
Ernesto Pacheco
于10/25/22注册
277 声望
创作了2篇指南
团队
Gateway, Team 1-1, Pee Fall 2022 Gateway, Team 1-1, Pee Fall 2022 的会员
GCC-PEE-F22S1G1
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 20
总计 212
