跳转到主内容
ACER Aspire V5-571P-6609 Battery Replacement
你所需要的
  1. ACER Aspire V5-571P-6609 Battery Replacement, Battery Replacement: 步骤 1 中的图像 1,1
    • Place the laptop facing down and find the slider close to the battery.
    • Use a screwdriver or other pointed tool to slide it to the right.
  2. ACER Aspire V5-571P-6609 Battery Replacement: 步骤 2 中的图像 1,1
    • While keeping the slider pushed to the right, use your other hand to pull the battery out from the right side to the left until it completely comes out.
  3. ACER Aspire V5-571P-6609 Battery Replacement: 步骤 3 中的图像 1,1
    • Install the new battery with the little tabs facing the laptop. Although keeping the slider pushed to the right when installing the new battery is recommended, it is not necessary; the battery can be inserted until it clicks in place.
结论
No Reassembly Required
Mauricio O.
于08/25/22注册
97 声望
撰写一个指南
团队
Gateway, Team 1-1, Pee Fall 2022 Gateway, Team 1-1, Pee Fall 2022 的会员
GCC-PEE-F22S1G1
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 10
总计 228
