跳转到主内容
ACER Aspire E1-572-6870 Screen Replacement
你所需要的
  1. ACER Aspire E1-572-6870 Screen Replacement, Battery: 步骤 1 中的图像 1,1
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Flip your laptop over so the back panel is facing upwards.
    • Locate the lock switch below the battery.
  2. ACER Aspire E1-572-6870 Screen Replacement: 步骤 2 中的图像 1,3 ACER Aspire E1-572-6870 Screen Replacement: 步骤 2 中的图像 2,3 ACER Aspire E1-572-6870 Screen Replacement: 步骤 2 中的图像 3,3
    • Slide the lock switch to the right using your finger or a spudger.
    • At the same time, grasp the battery with your other hand and slide it out of the laptop.
    • Remove the battery.
    • To reinsert or replace the battery, simply line up the tabs on the battery with the laptop and slide it straight back in. There is no need to move the lock switch.
  3. ACER Aspire E1-572-6870 Screen Replacement, Back Panel: 步骤 3 中的图像 1,2 ACER Aspire E1-572-6870 Screen Replacement, Back Panel: 步骤 3 中的图像 2,2
    • Remove the 16 2.5 x 8mm Phillips #0 screws from the back panel.
  4. ACER Aspire E1-572-6870 Screen Replacement: 步骤 4 中的图像 1,3 ACER Aspire E1-572-6870 Screen Replacement: 步骤 4 中的图像 2,3 ACER Aspire E1-572-6870 Screen Replacement: 步骤 4 中的图像 3,3
    • Remove the back panel by carefully disengaging it around the edges and then pull upwards.
  5. ACER Aspire E1-572-6870 Screen Replacement: 步骤 5 中的图像 1,1
    • Unscrew the two remaining 2.5 x 8mm Phillips #0 screws from inside the bottom panel as designated in the image.
  6. ACER Aspire E1-572-6870 Screen Replacement: 步骤 6 中的图像 1,2 ACER Aspire E1-572-6870 Screen Replacement: 步骤 6 中的图像 2,2
    • Slide out the plastic insert located on the left side, and remove, before returning the laptop to the face-up position.
  7. ACER Aspire E1-572-6870 Screen Replacement: 步骤 7 中的图像 1,3 ACER Aspire E1-572-6870 Screen Replacement: 步骤 7 中的图像 2,3 ACER Aspire E1-572-6870 Screen Replacement: 步骤 7 中的图像 3,3
    • Carefully flip your laptop back over and open it up.
  8. ACER Aspire E1-572-6870 Screen Replacement: 步骤 8 中的图像 1,3 ACER Aspire E1-572-6870 Screen Replacement: 步骤 8 中的图像 2,3 ACER Aspire E1-572-6870 Screen Replacement: 步骤 8 中的图像 3,3
    • Carefully detach the top panel of the laptop and slowly lift it up to reveal the internal components.
  9. ACER Aspire E1-572-6870 Screen Replacement: 步骤 9 中的图像 1,2 ACER Aspire E1-572-6870 Screen Replacement: 步骤 9 中的图像 2,2
    • Locate the three ribbons that need to be unplugged, so the two halves of the device may be separated.
    • Unplug the large ribbon by sliding the retainer clip backward (toward the hinges), then gently pulling the cable out of the connector.
  10. ACER Aspire E1-572-6870 Screen Replacement: 步骤 10 中的图像 1,3 ACER Aspire E1-572-6870 Screen Replacement: 步骤 10 中的图像 2,3 ACER Aspire E1-572-6870 Screen Replacement: 步骤 10 中的图像 3,3
    • Remove the other two smaller ribbons by flipping open the small plastic tab that holds the ribbon in the connector.
    • Then simply pull the free ribbon out.
  11. ACER Aspire E1-572-6870 Screen Replacement: 步骤 11 中的图像 1,2 ACER Aspire E1-572-6870 Screen Replacement: 步骤 11 中的图像 2,2
    • Lift the top panel all the way up and your laptop is now split into its two distinct halves.
  12. ACER Aspire E1-572-6870 Screen Replacement, Screen: 步骤 12 中的图像 1,2 ACER Aspire E1-572-6870 Screen Replacement, Screen: 步骤 12 中的图像 2,2
    • Remove the five 2.5 x 4.5mm Phillips #0 screws with a Phillips #0 screwdriver (three on the left, two on the right).
  13. ACER Aspire E1-572-6870 Screen Replacement: 步骤 13 中的图像 1,1
    • Unscrew the #00 Phillips screws holding the hinge together on each side of the screen.
  14. ACER Aspire E1-572-6870 Screen Replacement: 步骤 14 中的图像 1,3 ACER Aspire E1-572-6870 Screen Replacement: 步骤 14 中的图像 2,3 ACER Aspire E1-572-6870 Screen Replacement: 步骤 14 中的图像 3,3
    • Use a plastic opening tool to carefully separate the plastic frame from the screen.
  15. ACER Aspire E1-572-6870 Screen Replacement: 步骤 15 中的图像 1,2 ACER Aspire E1-572-6870 Screen Replacement: 步骤 15 中的图像 2,2
    • Remove the four 1.4 x 2 mm Phillips #00 screws with a Phillips #00 screwdriver.
  16. ACER Aspire E1-572-6870 Screen Replacement: 步骤 16 中的图像 1,1
    • Separate the screen from the back plastic frame.
  17. ACER Aspire E1-572-6870 Screen Replacement: 步骤 17 中的图像 1,2 ACER Aspire E1-572-6870 Screen Replacement: 步骤 17 中的图像 2,2
    • Peel back the tape holding the electrical connecting cord to the screen.
    • Remove connector from port.
  18. ACER Aspire E1-572-6870 Screen Replacement: 步骤 18 中的图像 1,1
    • Screen has been removed from the top of the laptop.
结论
4等其他人完成本指南。
Cody Lim
于01/25/17注册
1,404 声望
创作了7篇指南
团队
Cal Poly, Team 9-6, Banghart Winter 2017 Cal Poly, Team 9-6, Banghart Winter 2017 的会员
CPSU-BANGHART-W17S9G6
3 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 33
总计 4,726
