简介
This guide will show you how to properly remove the keyboard.
你所需要的
Flip your laptop over so the back panel is facing upwards.
Locate the lock switch below the battery.
Separate the top panel from the rest of the laptop.
Remove the yellow tape and then remove the three 1.4 x 2 mm Phillips #00 screws with a Phillips #00 screwdriver.
7等其他人完成本指南。
一条评论
If installing a new keyboard, remember to pull the keyboard cable through the metal panel before screwing it back in.
