跳转到主内容
ACER Aspire E1-572-6870 Hard Drive (HDD) Replacement
你所需要的
  1. ACER Aspire E1-572-6870 Hard Drive (HDD) Replacement, Battery: 步骤 1 中的图像 1,1
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Flip your laptop over so the back panel is facing upwards.
    • Locate the lock switch below the battery.
  2. ACER Aspire E1-572-6870 Hard Drive (HDD) Replacement: 步骤 2 中的图像 1,3 ACER Aspire E1-572-6870 Hard Drive (HDD) Replacement: 步骤 2 中的图像 2,3 ACER Aspire E1-572-6870 Hard Drive (HDD) Replacement: 步骤 2 中的图像 3,3
    • Slide the lock switch to the right using your finger or a spudger.
    • At the same time, grasp the battery with your other hand and slide it out of the laptop.
    • Remove the battery.
    • To reinsert or replace the battery, simply line up the tabs on the battery with the laptop and slide it straight back in. There is no need to move the lock switch.
  3. ACER Aspire E1-572-6870 Hard Drive (HDD) Replacement, Hard Drive (HDD): 步骤 3 中的图像 1,1
    • Unscrew the one 8mm Phillips #0 screw from the bottom panel.
  4. ACER Aspire E1-572-6870 Hard Drive (HDD) Replacement: 步骤 4 中的图像 1,3 ACER Aspire E1-572-6870 Hard Drive (HDD) Replacement: 步骤 4 中的图像 2,3 ACER Aspire E1-572-6870 Hard Drive (HDD) Replacement: 步骤 4 中的图像 3,3
    • Remove the back panel by carefully disengaging it around the edges and then pulling upwards.
  5. ACER Aspire E1-572-6870 Hard Drive (HDD) Replacement: 步骤 5 中的图像 1,1
    • Remove the other 8mm Phillips #0 screw holding the hard drive to the rest of the laptop.
  6. ACER Aspire E1-572-6870 Hard Drive (HDD) Replacement: 步骤 6 中的图像 1,2 ACER Aspire E1-572-6870 Hard Drive (HDD) Replacement: 步骤 6 中的图像 2,2
    • Slide the hard drive to the left using a plastic opening tool.
  7. ACER Aspire E1-572-6870 Hard Drive (HDD) Replacement: 步骤 7 中的图像 1,3 ACER Aspire E1-572-6870 Hard Drive (HDD) Replacement: 步骤 7 中的图像 2,3 ACER Aspire E1-572-6870 Hard Drive (HDD) Replacement: 步骤 7 中的图像 3,3
    • To remove the hard drive, pull up and to the left using the plastic tab as shown on the left side of the hard drive.
结论
5等其他人完成本指南。
Cody Lim
于01/25/17注册
1,404 声望
创作了7篇指南
团队
Cal Poly, Team 9-6, Banghart Winter 2017 Cal Poly, Team 9-6, Banghart Winter 2017 的会员
CPSU-BANGHART-W17S9G6
3 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 19
总计 3,601
