跳转到主内容
ACER Aspire E1-572-6870 Battery Replacement
你所需要的
  1. ACER Aspire E1-572-6870 Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Flip your laptop over so the back panel is facing upwards.
    • Locate the lock switch below the battery.
  2. ACER Aspire E1-572-6870 Battery Replacement: 步骤 2 中的图像 1,3 ACER Aspire E1-572-6870 Battery Replacement: 步骤 2 中的图像 2,3 ACER Aspire E1-572-6870 Battery Replacement: 步骤 2 中的图像 3,3
    • Slide the lock switch to the right using your finger or a spudger.
    • At the same time, grasp the battery with your other hand and slide it out of the laptop.
    • Remove the battery.
    • To reinsert or replace the battery, simply line up the tabs on the battery with the laptop and slide it straight back in. There is no need to move the lock switch.
结论
For optimal performance, after completing this guide, calibrate your newly installed battery.
3等其他人完成本指南。
Cody Lim
于01/25/17注册
1,404 声望
创作了7篇指南
团队
Cal Poly, Team 9-6, Banghart Winter 2017 Cal Poly, Team 9-6, Banghart Winter 2017 的会员
CPSU-BANGHART-W17S9G6
3 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 18
过去 30 天: 46
总计 5,862
