简介
This guide will show you in depth how to replace the screen. This guide will use two prerequisite guides. In order to complete this guide you will have to know how to use a screwdriver and a suction cup. This guide requires time and a lot of patience.
你所需要的
Loosen the back cover using the suction cup.
Pull up on the center of the back with the suction cup.
Pull up on all four corners of the back with the suction cup.
Lift off the black audio cover.
I added a blue box around the audio cover and relabeled your instruction to be a blue dot instead of a black dot.
I also recommend retaking step 5's first photo with your hands out of the picture so that the person can see the whole black audio cover.
一条评论
Remember to give the lengths for all screws. For warnings, try to be more straight forward and try not to use words like '“note.” Remember to add an introduction.
