跳转到主内容
A Jammed SD Card Tray
你所需要的
  1. A Jammed SD Card Tray, A Jammed SD Card Tray: 步骤 1 中的图像 1,2 A Jammed SD Card Tray, A Jammed SD Card Tray: 步骤 1 中的图像 2,2
    • As you see the sd tray is bent in.
    • And you can’t get it open like usual.
  2. A Jammed SD Card Tray, Popping up tray: 步骤 2 中的图像 1,2 A Jammed SD Card Tray, Popping up tray: 步骤 2 中的图像 2,2
    • Pop up the sd port tray
  3. A Jammed SD Card Tray, Popping open tray: 步骤 3 中的图像 1,3 A Jammed SD Card Tray, Popping open tray: 步骤 3 中的图像 2,3 A Jammed SD Card Tray, Popping open tray: 步骤 3 中的图像 3,3
    • Here is the tool you need or something similar
    • PLEASE BE CAREFUL IT CAN DAMAGE THE EXPOSED MOTHERBOARD INSIDE IF NOT
  4. A Jammed SD Card Tray, Remove sd card: 步骤 4 中的图像 1,3 A Jammed SD Card Tray, Remove sd card: 步骤 4 中的图像 2,3 A Jammed SD Card Tray, Remove sd card: 步骤 4 中的图像 3,3
    • You have to press down on sd like the physical game to get it out
    • And don’t forget to close the tray
结论
Thanks and you’re welcome now you have free access to your sd card!
另外一个人完成了本指南。
Sqwerks
于10/31/22注册
563 声望
撰写一个指南
团队
The Sqwerks repair team The Sqwerks repair team 的会员
Community
1 名成员
创作了2篇指南
4指南评论
My first guide 😂
Sqwerks - 回复
its been officially accepted as of two months ago yahoo
Sqwerks - 回复
also i sold the 3ds to @tronicsfix (if your reading this sorry) but yea (just so you know I'm here as well)
Sqwerks - 回复
it was by wild chance even though they are my main inspiration and got me into ifixit
Sqwerks - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 14
过去 30 天: 52
总计 1,443
