跳转到主内容
你所需要的
本篇指南是分解流程而非维修指南。 如果您要维修您的Candle lamp,应参考我们的维修指南
  1. A Candle lamp, Get prepare: 步骤 1 中的图像 1,1
    • The product before teardown
    • From its initial look, it can mainly separate into four parts. The top ( lamp shade) , the stand ( the tube ) , the base and the wire & controller.
    • Overall product dimension : 290 x 185x 150mm . Weight : 585 gram
  2. A Candle lamp, Remove the base cap: 步骤 2 中的图像 1,1
    • The back of the lamp base was pulled off and flipped over revealing the base structure. Here a craft knife was used for the removal.
    • The cap functions as a cover to hide the cable , its material is High-density Polyethylene ( HDPE) and is injection molded.
    • The dimension is 15cm diameter x5mm thickness , its weight is 29g.
  3. A Candle lamp, Cut the lock: 步骤 3 中的图像 1,1
    • The white lock to secure the wire and it was removed by a grip and a wire cutter
    • The lamp base is a platform for a candle to sit on top, this view is a close up to see where does the cable goes
    • The lamp base is made of mild steel and it’s about 15cm diameter x2.7cm height with 142grams in weight.
  4. A Candle lamp, Remove the Hex nuts: 步骤 4 中的图像 1,1
    • The hex nut was removed by the spanner.
    • The number 6 spanner was used
  5. A Candle lamp, Remove screws: 步骤 5 中的图像 1,1
    • Remove the screws inside the light bulb connector
    • The screws are machined made and the type of screws is a mushroom-head with 4mm head diameter 10mm tall.
  6. A Candle lamp, Cut the light bulb connector: 步骤 6 中的图像 1,1
    • Cut the connector head and pull out the cable after removing the nut from both sides
    • The image showed a light bulb connector and its probably a HDPE or Acrylonitrile Butadiene Styrene (ABS) plastic , injection melded , overall dimension is 28mm diameter x 17mm in height
  7. A Candle lamp, Remove the control panel case: 步骤 7 中的图像 1,1
    • Remove the control panel case by unfastening the screw
    • The case functions to protect damages from the circuit board and it’s made by ABS/ HDPE , injection molded with an overall dimension 900mm length x 400 width x10 height, 21gram in weight
  8. A Candle lamp, Pull out cable: 步骤 8 中的图像 1,1
    • Pull out the cable from the tube
    • The cable jacket is PVC , 1230mm length with 6mm thickness , weigh in 78gram
  9. A Candle lamp, Separate parts: 步骤 9 中的图像 1,1
    • Separate parts : the nuts , the lamp stand, the lamp shade , the base, the controller case , the dimmerable knot and the screws
  10. A Candle lamp, Small parts close-up: 步骤 10 中的图像 1,1
    • Here is the small component close-up shot of the diassembly of the candle lamp
  11. A Candle lamp, The product teardown: 步骤 11 中的图像 1,1
    • Finished the product teardown. There are about 14 components of it.
Ut Mio Vu
于03/27/24注册
193 声望
撰写一个指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 26
总计 337
