跳转到主内容
8BitDo SN30 Pro+ Controller Triggers Replacement
你所需要的
  1. 8BitDo SN30 Pro+ Controller Triggers Replacement, Remove Battery: 步骤 1 中的图像 1,3 8BitDo SN30 Pro+ Controller Triggers Replacement, Remove Battery: 步骤 1 中的图像 2,3 8BitDo SN30 Pro+ Controller Triggers Replacement, Remove Battery: 步骤 1 中的图像 3,3
    • Place the controller face down.
    • Remove the battery cover.
    • Remove rechargeable battery or AA batteries.
  2. 8BitDo SN30 Pro+ Controller Triggers Replacement, Remove Trigger Buttons: 步骤 2 中的图像 1,2 8BitDo SN30 Pro+ Controller Triggers Replacement, Remove Trigger Buttons: 步骤 2 中的图像 2,2
    • Remove L2 and R2 trigger buttons by pushing them away from the grips.
  3. 8BitDo SN30 Pro+ Controller Triggers Replacement, Remove Screws: 步骤 3 中的图像 1,2 8BitDo SN30 Pro+ Controller Triggers Replacement, Remove Screws: 步骤 3 中的图像 2,2
    在这个步骤中使用的工具:
    • Use Tweezers to uncover two screws under the label in the battery compartment.
    • Use a T6 screwdriver to remove the four 7.3 mm screws securing the rear cover.
  4. 8BitDo SN30 Pro+ Controller Triggers Replacement, Unclip Covers: 步骤 4 中的图像 1,3 8BitDo SN30 Pro+ Controller Triggers Replacement, Unclip Covers: 步骤 4 中的图像 2,3 8BitDo SN30 Pro+ Controller Triggers Replacement, Unclip Covers: 步骤 4 中的图像 3,3
    • At the end of each grip, pry apart the covers.
    • Use fingernail or opening pick to undo the two top clips.
    • One clip next to L button.
    • One clip next to R button
    • Undo the final clip between the joysticks.
  5. 8BitDo SN30 Pro+ Controller Triggers Replacement, Separate Covers: 步骤 5 中的图像 1,1
    • Carefully move the rear cover away and from the front cover. Place it to the left.
    • Do not completely separate. The two halves are still attached via a white ribbon cable.
  6. 8BitDo SN30 Pro+ Controller Triggers Replacement, Remove Ribbon Cable: 步骤 6 中的图像 1,3 8BitDo SN30 Pro+ Controller Triggers Replacement, Remove Ribbon Cable: 步骤 6 中的图像 2,3 8BitDo SN30 Pro+ Controller Triggers Replacement, Remove Ribbon Cable: 步骤 6 中的图像 3,3
    • Unlock the ribbon cable by push open the black plastic tab.
    • The tab will slide about 1.5mm
    • Pull the ribbon cable out of the connector in the direction of the cable.
  7. 8BitDo SN30 Pro+ Controller Triggers Replacement, Remove Screws: 步骤 7 中的图像 1,3 8BitDo SN30 Pro+ Controller Triggers Replacement, Remove Screws: 步骤 7 中的图像 2,3 8BitDo SN30 Pro+ Controller Triggers Replacement, Remove Screws: 步骤 7 中的图像 3,3
    • Use a Phillips screwdriver to remove the seven screws securing the main circuit board.
    • Six 10.1mm screws
    • One 5.8mm screws
  8. 8BitDo SN30 Pro+ Controller Triggers Replacement, Separate Main Board: 步骤 8 中的图像 1,3 8BitDo SN30 Pro+ Controller Triggers Replacement, Separate Main Board: 步骤 8 中的图像 2,3 8BitDo SN30 Pro+ Controller Triggers Replacement, Separate Main Board: 步骤 8 中的图像 3,3
    • Slide the R buttons up and off its peg.
    • Slide the L button up and off its peg.
    • Remove the main board by rotating it towards the USB-C port. Then lift it out.
  9. 8BitDo SN30 Pro+ Controller Triggers Replacement, Remove Trigger Assembly: 步骤 9 中的图像 1,3 8BitDo SN30 Pro+ Controller Triggers Replacement, Remove Trigger Assembly: 步骤 9 中的图像 2,3 8BitDo SN30 Pro+ Controller Triggers Replacement, Remove Trigger Assembly: 步骤 9 中的图像 3,3
    • Release the three clips holding the trigger assembly to the main board.
    • Repeat with the other side.
  10. 8BitDo SN30 Pro+ Controller Triggers Replacement, Remove Trigger: 步骤 10 中的图像 1,3 8BitDo SN30 Pro+ Controller Triggers Replacement, Remove Trigger: 步骤 10 中的图像 2,3 8BitDo SN30 Pro+ Controller Triggers Replacement, Remove Trigger: 步骤 10 中的图像 3,3
    • Bend the plastic tab over the locking hook. It helps to push the trigger back slightly, with your other hand.
    • Gently pry the each side of the trigger out of the round clips.
    • Both conductive pads are now accessible.
结论
另外一个人完成了本指南。
Brian W
于12/21/11注册
1,773 声望
创作了8篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 13
过去 30 天: 59
总计 4,196
