跳转到主内容
8BitDo SN30 Pro+ Controller Rumble Motors Replacement
你所需要的
  1. 8BitDo SN30 Pro+ Controller Rumble Motors Replacement, Remove Battery: 步骤 1 中的图像 1,3 8BitDo SN30 Pro+ Controller Rumble Motors Replacement, Remove Battery: 步骤 1 中的图像 2,3 8BitDo SN30 Pro+ Controller Rumble Motors Replacement, Remove Battery: 步骤 1 中的图像 3,3
    • Place the controller face down.
    • Remove the battery cover.
    • Remove rechargeable battery or AA batteries.
  2. 8BitDo SN30 Pro+ Controller Rumble Motors Replacement, Remove Trigger Buttons: 步骤 2 中的图像 1,2 8BitDo SN30 Pro+ Controller Rumble Motors Replacement, Remove Trigger Buttons: 步骤 2 中的图像 2,2
    • Remove L2 and R2 trigger buttons by pushing them away from the grips.
  3. 8BitDo SN30 Pro+ Controller Rumble Motors Replacement, Remove Screws: 步骤 3 中的图像 1,2 8BitDo SN30 Pro+ Controller Rumble Motors Replacement, Remove Screws: 步骤 3 中的图像 2,2
    在这个步骤中使用的工具:
    • Use Tweezers to uncover two screws under the label in the battery compartment.
    • Use a T6 screwdriver to remove the four 7.3 mm screws securing the rear cover.
  4. 8BitDo SN30 Pro+ Controller Rumble Motors Replacement, Unclip Covers: 步骤 4 中的图像 1,3 8BitDo SN30 Pro+ Controller Rumble Motors Replacement, Unclip Covers: 步骤 4 中的图像 2,3 8BitDo SN30 Pro+ Controller Rumble Motors Replacement, Unclip Covers: 步骤 4 中的图像 3,3
    • At the end of each grip, pry apart the covers.
    • Use fingernail or opening pick to undo the two top clips.
    • One clip next to L button.
    • One clip next to R button
    • Undo the final clip between the joysticks.
  5. 8BitDo SN30 Pro+ Controller Rumble Motors Replacement, Separate Covers: 步骤 5 中的图像 1,1
    • Carefully move the rear cover away and from the front cover. Place it to the left.
    • Do not completely separate. The two halves are still attached via a white ribbon cable.
  6. 8BitDo SN30 Pro+ Controller Rumble Motors Replacement, Remove Ribbon Cable: 步骤 6 中的图像 1,3 8BitDo SN30 Pro+ Controller Rumble Motors Replacement, Remove Ribbon Cable: 步骤 6 中的图像 2,3 8BitDo SN30 Pro+ Controller Rumble Motors Replacement, Remove Ribbon Cable: 步骤 6 中的图像 3,3
    • Unlock the ribbon cable by push open the black plastic tab.
    • The tab will slide about 1.5mm
    • Pull the ribbon cable out of the connector in the direction of the cable.
  7. 8BitDo SN30 Pro+ Controller Rumble Motors Replacement, Remove Caps: 步骤 7 中的图像 1,2 8BitDo SN30 Pro+ Controller Rumble Motors Replacement, Remove Caps: 步骤 7 中的图像 2,2
    • Grab the top and pull straight up on the joystick cap. Pulling out the caps one-by-one.
  8. 8BitDo SN30 Pro+ Controller Rumble Motors Replacement, Remove Screws: 步骤 8 中的图像 1,3 8BitDo SN30 Pro+ Controller Rumble Motors Replacement, Remove Screws: 步骤 8 中的图像 2,3 8BitDo SN30 Pro+ Controller Rumble Motors Replacement, Remove Screws: 步骤 8 中的图像 3,3
    • Use a Phillips screwdriver to remove the nine 5.2 mm screws securing the rear circuit board.
    • Four around the Right stick
    • Four around the Left stick
    • One next to the Battery connector
  9. 8BitDo SN30 Pro+ Controller Rumble Motors Replacement, Separate Rear Board: 步骤 9 中的图像 1,3 8BitDo SN30 Pro+ Controller Rumble Motors Replacement, Separate Rear Board: 步骤 9 中的图像 2,3 8BitDo SN30 Pro+ Controller Rumble Motors Replacement, Separate Rear Board: 步骤 9 中的图像 3,3
    • Pull the two rumble motors out of their housings.
    • Grab the analog sticks to pull out the circuit board
  10. 8BitDo SN30 Pro+ Controller Rumble Motors Replacement, Desolder Rumble Motors: 步骤 10 中的图像 1,3 8BitDo SN30 Pro+ Controller Rumble Motors Replacement, Desolder Rumble Motors: 步骤 10 中的图像 2,3 8BitDo SN30 Pro+ Controller Rumble Motors Replacement, Desolder Rumble Motors: 步骤 10 中的图像 3,3
    • Flip over the rear board
    • Using a soldering iron to desolder the rumble motor wires.
    • During reassembly, remember to solder the wires back into the same position.
结论
另外一个人完成了本指南。
Brian W
于12/21/11注册
1,773 声望
创作了8篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 17
总计 766
