跳转到主内容
加入维修社区 - 创建账户
8BitDo SN30 Pro+ Controller Joystick Caps Replacement
你所需要的
  1. 8BitDo SN30 Pro+ Controller Joystick Caps Replacement, Remove Battery: 步骤 1 中的图像 1,3 8BitDo SN30 Pro+ Controller Joystick Caps Replacement, Remove Battery: 步骤 1 中的图像 2,3 8BitDo SN30 Pro+ Controller Joystick Caps Replacement, Remove Battery: 步骤 1 中的图像 3,3
    • Place the controller face down.
    • Remove the battery cover.
    • Remove rechargeable battery or AA batteries.
  2. 8BitDo SN30 Pro+ Controller Joystick Caps Replacement, Remove Trigger Buttons: 步骤 2 中的图像 1,2 8BitDo SN30 Pro+ Controller Joystick Caps Replacement, Remove Trigger Buttons: 步骤 2 中的图像 2,2
    • Remove L2 and R2 trigger buttons by pushing them away from the grips.
  3. 8BitDo SN30 Pro+ Controller Joystick Caps Replacement, Remove Screws: 步骤 3 中的图像 1,2 8BitDo SN30 Pro+ Controller Joystick Caps Replacement, Remove Screws: 步骤 3 中的图像 2,2
    在这个步骤中使用的工具:
    • Use Tweezers to uncover two screws under the label in the battery compartment.
    • Use a T6 screwdriver to remove the four 7.3 mm screws securing the rear cover.
  4. 8BitDo SN30 Pro+ Controller Joystick Caps Replacement, Unclip Covers: 步骤 4 中的图像 1,3 8BitDo SN30 Pro+ Controller Joystick Caps Replacement, Unclip Covers: 步骤 4 中的图像 2,3 8BitDo SN30 Pro+ Controller Joystick Caps Replacement, Unclip Covers: 步骤 4 中的图像 3,3
    • At the end of each grip, pry apart the covers.
    • Use fingernail or opening pick to undo the two top clips.
    • One clip next to L button.
    • One clip next to R button
    • Undo the final clip between the joysticks.
  5. 8BitDo SN30 Pro+ Controller Joystick Caps Replacement, Separate Covers: 步骤 5 中的图像 1,1
    • Carefully move the rear cover away and from the front cover. Place it to the left.
    • Do not completely separate. The two halves are still attached via a white ribbon cable.
  6. 8BitDo SN30 Pro+ Controller Joystick Caps Replacement, Remove Caps: 步骤 6 中的图像 1,3 8BitDo SN30 Pro+ Controller Joystick Caps Replacement, Remove Caps: 步骤 6 中的图像 2,3 8BitDo SN30 Pro+ Controller Joystick Caps Replacement, Remove Caps: 步骤 6 中的图像 3,3
    • Grab the top and pull straight up on the joystick cap. Pulling out the caps one-by-one.
  7. 8BitDo SN30 Pro+ Controller Joystick Caps Replacement, Installing New Caps: 步骤 7 中的图像 1,3 8BitDo SN30 Pro+ Controller Joystick Caps Replacement, Installing New Caps: 步骤 7 中的图像 2,3 8BitDo SN30 Pro+ Controller Joystick Caps Replacement, Installing New Caps: 步骤 7 中的图像 3,3
    • One at a time, Orient the new cap to match the analog stick.
    • Push the cap straight down onto the analog stick.
    • You should hear the click of the stick button
结论
11等其他人完成本指南。
Brian W
于12/21/11注册
1,773 声望
创作了8篇指南
5指南评论
Was wondering, does other brand joystick cap other than 8bitdo (eg:ps4, ps5, xbox one) fits ?
Lee Han Chang - 回复 分享
looks like PS5 hole size and cone shape. Confirmation needed.
Gustavo Klein Martins - 分享
I did the repair with a third party analog cap meant for the PS5 (being extra cheap) on the Pro 2. Despite the bottom hole being bigger on the original, the replacement joystick fit right in.
TorxT6 - 分享
Did you manage to find a replacement? Looking for an alternative as well since 8bitdo doesn't ship here.
Joseph Johansson - 回复 分享
Hello Joseph, I've purchased my replacements from Core Electronics with no issues, how ever they are based in Australia so unsure if they will ship to where you need them.
Darryn Stanmore - 分享
添加评论
浏览统计数据:
过去 24 小时: 8
过去 7 天: 29
过去 30 天: 165
总计 5,919
