跳转到主内容
6. Installing Klipper Screen
  1. 6. Installing Klipper Screen, 6. Installing Klipper Screen: 步骤 1 中的图像 1,1
    • You need to set the OS to boot to console
    • sudo raspi-config
    • 1 System Options > S5 Boot / Auto Login > B1 Console. Then reboot
    • Download and install KlipperScreen
    • git clone https://github.com/jordanruthe/KlipperSc...
    • cd ~/KlipperScreen
    • ./scripts/KlipperScreen-install.sh
    • When the install is finished reboot the RPI. This will take some time to install so feel free to get yourself a cold beverage and relax for a little bit.
  2. 6. Installing Klipper Screen: 步骤 2 中的图像 1,1
    • If you loaded my config files it should already be included but check moonraker.conf contains:
    • [authorization] under trusted clients contains 127.0.0.1
    • [update manager KlipperScreen]
  3. 6. Installing Klipper Screen: 步骤 3 中的图像 1,2 6. Installing Klipper Screen: 步骤 3 中的图像 2,2
    • If you used the latest version of Mainsail(v7.0) skip this next command.
    • git clone https://github.com/mainsail-crew/moonrak...
    • Regardless if you used the latest version or not run
    • bash ~/moonraker-timelapse/install.sh
    • Make sure printer.cfg calls the timelapse config
    • [include timelapse.cfg]
    • Make sure the [timelapse] section is uncommented in moonraker.conf
终点
David Husolo
于06/16/21注册
9,232 声望
创作了33篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 12
总计 1,959
