跳转到主内容
4-Stroke Small Gas Engine Air Filter Replacement
你所需要的
  1. 4-Stroke Small Gas Engine Air Filter Replacement, Air Filter: 步骤 1 中的图像 1,3 4-Stroke Small Gas Engine Air Filter Replacement, Air Filter: 步骤 1 中的图像 2,3 4-Stroke Small Gas Engine Air Filter Replacement, Air Filter: 步骤 1 中的图像 3,3
    • Before starting, ensure that the engine is not running and is not hot.
    • Pull the tab until the filter cover opens. Remove the filter cover.
    • Note that the bottom of the cover is hinged.
  2. 4-Stroke Small Gas Engine Air Filter Replacement: 步骤 2 中的图像 1,1
    • Remove the air filter.
    • The air filter will be either an oily sponge, or an accordion-folded fabric.
    • Note that the air filter is saturated with oil. Wear gloves and use paper towels to avoid creating a mess.
结论
2等其他人完成本指南。
Ethan Narad
于04/19/18注册
529 声望
创作了3篇指南
团队
Cal Poly, Team S25-G15, Maness Spring 2018 Cal Poly, Team S25-G15, Maness Spring 2018 的会员
CPSU-MANESS-S18S25G15
4 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 13
总计 675
