跳转到主内容
加入维修社区 - 创建账户
3rd party DualShock 2 Wireless Controller Analog Stick Replacement
你所需要的
  1. 3rd party DualShock 2 Wireless Controller Analog Stick Replacement, Analog Stick: 步骤 1 中的图像 1,2 3rd party DualShock 2 Wireless Controller Analog Stick Replacement, Analog Stick: 步骤 1 中的图像 2,2
    • Remove the six 7.8 mm anchoring screws from the back casing of the controller using a Phillips #0 screwdriver.
    添加评论
  2. 3rd party DualShock 2 Wireless Controller Analog Stick Replacement: 步骤 2 中的图像 1,2 3rd party DualShock 2 Wireless Controller Analog Stick Replacement: 步骤 2 中的图像 2,2
    • Pull apart the outer casing by hand, or by using a plastic opening tool, from the bottom of the controller.
    • Be mindful not to sever the connection between the battery pack attached to the back casing and the internal board
    询问修复机器人
    添加评论
  3. 3rd party DualShock 2 Wireless Controller Analog Stick Replacement: 步骤 3 中的图像 1,2 3rd party DualShock 2 Wireless Controller Analog Stick Replacement: 步骤 3 中的图像 2,2
    • Remove the two 6.1 mm screws holding the internal analog stick board and the front of the controller together.
    询问修复机器人
    添加评论
  4. 3rd party DualShock 2 Wireless Controller Analog Stick Replacement: 步骤 4 中的图像 1,2 3rd party DualShock 2 Wireless Controller Analog Stick Replacement: 步骤 4 中的图像 2,2
    • Lift the analog stick board away from the front of the controller.
    • Remove the detached or loose analog stick for realignment.
    询问修复机器人
    添加评论
  5. 3rd party DualShock 2 Wireless Controller Analog Stick Replacement: 步骤 5 中的图像 1,1
    • Realign the analog stick by pushing the removed stick back into its chassis with focus on pushing it in at the new, desired resting angle. You should feel or hear a small click if done correctly.
    • The stick may not immediately click into place under the pressure. Instead of pushing harder, try rotating the stick 90 degrees and pushing down again.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
25等其他人完成本指南。
团队
Texas Tech, Team S1-G1, Rauch Summer 2017 Texas Tech, Team S1-G1, Rauch Summer 2017 的会员
TTU-RAUCH-SU17S1G1
2 名成员
创作了4篇指南
1指南评论
The controller featured here is not an official Dualshock 2 controller.
Synapse - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 20
过去 7 天: 85
过去 30 天: 345
总计 20,013
