跳转到主内容
3DR Solo Leg Replacement
你所需要的
  1. 3DR Solo Leg Replacement, Propeller: 步骤 1 中的图像 1,1
    • Grip the arm, which is located underneath the propeller, with one hand, and with your dominant hand grip the center of the propeller.
  2. 3DR Solo Leg Replacement: 步骤 2 中的图像 1,1
    • Twist the propeller from the locked to unlocked position as indicated by the images of the lock.
    • You will need to twist in this direction for 2-3 full rotations before the propeller will detach.
  3. 3DR Solo Leg Replacement: 步骤 3 中的图像 1,1
    • Lift the propeller off the motor.
    • To remove the silver-top propellers, repeat these steps, turning the propellers in the opposite direction of the black-top propellers.
  4. 3DR Solo Leg Replacement, Leg: 步骤 4 中的图像 1,1
    • Place the controller on a flat surface with the battery side down.
  5. 3DR Solo Leg Replacement: 步骤 5 中的图像 1,3 3DR Solo Leg Replacement: 步骤 5 中的图像 2,3 3DR Solo Leg Replacement: 步骤 5 中的图像 3,3
    • Locate the leg and remove the two 10mm screws that hold the leg in place.
  6. 3DR Solo Leg Replacement: 步骤 6 中的图像 1,1
    • Gently pull the leg up to remove it from its position.
    • Leg should be connected by a black wire.
  7. 3DR Solo Leg Replacement: 步骤 7 中的图像 1,3 3DR Solo Leg Replacement: 步骤 7 中的图像 2,3 3DR Solo Leg Replacement: 步骤 7 中的图像 3,3
    • Locate the rubber grip at the end of the leg and, with your thumb, peel it back and pull it off.
  8. 3DR Solo Leg Replacement: 步骤 8 中的图像 1,2 3DR Solo Leg Replacement: 步骤 8 中的图像 2,2
    • Leg type 1 will contain a 1mm screw at the base of the leg.
    • Unscrew the 1mm screw located at the end of the leg.
  9. 3DR Solo Leg Replacement: 步骤 9 中的图像 1,1
    • Gently pull the black cord up to release it from the leg.
  10. 3DR Solo Leg Replacement: 步骤 10 中的图像 1,3 3DR Solo Leg Replacement: 步骤 10 中的图像 2,3 3DR Solo Leg Replacement: 步骤 10 中的图像 3,3
    • Leg type 2 will contain the antenna wire.
    • Gently pull up on and remove the plastic covering labeled "solo antenna".
    • Locate the antenna wire and carefully pull up and remove it.
    • The antenna wire is flimsy so use caution upon removal.
结论
Leia Harlow
于09/11/17注册
101 声望
撰写一个指南
团队
CSU Fullerton, Team S2-G3, Bruce Fall 2017 CSU Fullerton, Team S2-G3, Bruce Fall 2017 的会员
CSUF-BRUCE-F17S2G3
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 5
总计 326
