你所需要的
The mechanism has a wire harness that runs down to the main PCB in the chair. Most of our 3D mechs come with a new harness pre-attached and the old harness will need to be disconnected from the quick disconnect .
Don't disconnect these if your new mechanism has them pre-attached.
This is an extremely vague photo , but the quick disconnect is located in the sheath on the lower left hand side of the chair . DON"T CUT THE SHEATHING JUST THE ZIP TIES . If you cant get this zip tied onto the frame like the factory had it no worries just make sure its secured in the general location with zip ties .
This is the entire upper harness that connects to the 3D mechanism .
Lower harness that connects to main PCB . see last step for location
Quick disconnect . located on frame .
Remove the 3 screws on the lower power box cover to gain access to the lower wire harness
unscrew the wire harness clip by removing the 2 screws
These marked connectors are the motor wires and these are not all of the wires on this harness. please see last step
Now remove the upper limit sensor from the 3 plastic pins and move it aside away from the magnet. DO NOT UNPLUG IT
Put the chair into Manual Shiatsu and hit the zone button 2 times , sometimes 1 press. You will know you did it right because the arrows will light up in the middle.
Shows if your in shiatsu mode .
Once these arrows are glowing you can drive the the mech out the top of chair using the UP arrow.
If for some reason you cant get the mechanism into the chair due to the top axle blocking it . Its due to this 3D gear not being set at the correct angle.
To fix the angle simply remove this cover by removing the 2 screws and spin the motor belt until angle is correct.
