跳转到主内容
简介
This guide walks you through how to replace the SD memory card on a 360fly 4K camera.
  1. Flip the camera upside down and peel off the two plastic screw covers with the metal spudger to reveal the screws.
    • Flip the camera upside down and peel off the two plastic screw covers with the metal spudger to reveal the screws.
  2. Remove the two 5mm T4 screws from the bottom of the camera with a t4 screw driver.
    • Remove the two 5mm T4 screws from the bottom of the camera with a t4 screw driver.
  3. Gently pry the plastic ring from around the charging plate with the metal spudger. Remove the outside shell by pressing against the center of the charging plate and pulling the bottom shell away from the top shell.
    • Gently pry the plastic ring from around the charging plate with the metal spudger.
    • Remove the outside shell by pressing against the center of the charging plate and pulling the bottom shell away from the top shell.
  4. Remove the five 2mm T4 screws and pull off the charging plate assmebly with the t4 screw driver.
    • Remove the five 2mm T4 screws and pull off the charging plate assmebly with the t4 screw driver.
  5. Gently pry the plug off the port on the circuit board with a plastic opening tool. Remove the four 2mm T4 screws and take off the circuit board with a T4 screw driver.
    • Gently pry the plug off the port on the circuit board with a plastic opening tool.
    • Remove the four 2mm T4 screws and take off the circuit board with a T4 screw driver.
  6. Remove the five 4mm T4 screws around the battery assembly with a t4 crew driver. Lift the battery assembly and gently pry the plug out of its port on the board below with a plastic opening tool. Press the battery from the back  of the battery assembly to remove it with a plastic opening tool until the glue releases the battery.
    • Remove the five 4mm T4 screws around the battery assembly with a t4 crew driver.
    • Lift the battery assembly and gently pry the plug out of its port on the board below with a plastic opening tool.
    • Press the battery from the back of the battery assembly to remove it with a plastic opening tool until the glue releases the battery.
    • Do not puncture or bend the battery. Use a small amount of heat to assist in softening the adhesive if necessary.
    Do I have to remove the battery to replace the SD card?
    BoB - 回复
  7. Gently pry the plug from  the motherboard and remove the motherboard from the assembly.
    • Gently pry the plug from the motherboard and remove the motherboard from the assembly.
  8. Remove the  three 3mm T4 screws from the circuit assembly with a T4 screwdriver.
    • Remove the three 3mm T4 screws from the circuit assembly with a T4 screwdriver.
  9. Gently pry out the plug from the circuit assembly.
    • Gently pry out the plug from the circuit assembly.
  10. Press and release the SD card to remove it from the circuit assembly.
    • Press and release the SD card to remove it from the circuit assembly.
    Does anyone know how large a card the 360fly can support? I’d like to put a 256gb card in if it will support it.
    BoB - 回复
结论
3等其他人完成本指南。
Jacob Herron
于2017年11月08日注册
421 信誉积分
创作了3篇指南
团队
IUPUI, Team S5-G3, Baechle Fall 2017 IUPUI, Team S5-G3, Baechle Fall 2017 的会员
IUPUI-BAECHLE-F17S5G3
3 名成员
创作了3篇指南
Really useful guide, thanks
John Erikson - 回复
添加评论
浏览统计数据:
过去的24小时: 3
过去的7天: 8
过去的30天: 24
总计 466
