跳转到主内容
360fly 4K Battery Replacement
你所需要的
  1. 360fly 4K Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Flip the camera upside down and peel off the two plastic screw covers with the metal spudger to reveal the screws.
  2. 360fly 4K Battery Replacement: 步骤 2 中的图像 1,1
    • Remove the two 5 mm screws from the bottom of the camera with a T4 screwdriver.
  3. 360fly 4K Battery Replacement: 步骤 3 中的图像 1,2 360fly 4K Battery Replacement: 步骤 3 中的图像 2,2
    • Gently pry the plastic ring from around the charging plate with the metal spudger.
    • Remove the outside shell by pressing against the center of the charging plate and pulling the bottom shell away from the top shell.
  4. 360fly 4K Battery Replacement: 步骤 4 中的图像 1,1
    • Remove the five 2 mm screws using a T4 screwdriver.
    • Pull off the charging plate assembly.
  5. 360fly 4K Battery Replacement: 步骤 5 中的图像 1,2 360fly 4K Battery Replacement: 步骤 5 中的图像 2,2
    • Gently pry the plug off the port on the circuit board with a plastic opening tool.
    • Remove the four 2 mm screws using a T4 screwdriver.
    • Remove the circuit board from the device.
  6. 360fly 4K Battery Replacement: 步骤 6 中的图像 1,3 360fly 4K Battery Replacement: 步骤 6 中的图像 2,3 360fly 4K Battery Replacement: 步骤 6 中的图像 3,3
    • Remove the five 4 mm screws around the battery assembly with a T4 screwdriver.
    • Lift the battery assembly and gently pry the plug out of its port on the board below with a plastic opening tool.
    • Press the battery from the back of the battery assembly to remove it with a plastic opening tool until the glue releases the battery.
    • Potential for device damage: Do not puncture or bend the battery. Use a small amount of heat to assist in softening the adhesive if necessary.
结论
2等其他人完成本指南。
Jacob Herron
于11/08/17注册
463 声望
创作了3篇指南
团队
IUPUI, Team S5-G3, Baechle Fall 2017 IUPUI, Team S5-G3, Baechle Fall 2017 的会员
IUPUI-BAECHLE-F17S5G3
3 名成员
创作了3篇指南
4条评论
Wich one battery Can I use to replace It?
Marco Pereira - 回复
Where can i purchase a battery
john hernandez - 回复
I would like to purchase a 360 fly battery
john hernandez - 回复
Where can I buy the battery?
Mark - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 42
总计 2,471
