跳转到主内容
2021 Toyota Venza Key Fob Battery Replacement
你所需要的
  1. 2021 Toyota Venza Key Fob Battery Replacement, Key Fob Battery: 步骤 1 中的图像 1,2 2021 Toyota Venza Key Fob Battery Replacement, Key Fob Battery: 步骤 1 中的图像 2,2
    • Flip the fob so the backside is facing up.
  2. 2021 Toyota Venza Key Fob Battery Replacement: 步骤 2 中的图像 1,3 2021 Toyota Venza Key Fob Battery Replacement: 步骤 2 中的图像 2,3 2021 Toyota Venza Key Fob Battery Replacement: 步骤 2 中的图像 3,3
    • Slide the lock to the right.
    • Pull the key out from the top of fob case.
  3. 2021 Toyota Venza Key Fob Battery Replacement: 步骤 3 中的图像 1,2 2021 Toyota Venza Key Fob Battery Replacement: 步骤 3 中的图像 2,2
    • Insert the tip of the key or a spudger into the space where the key was and begin to pry the two parts of the fob apart.
  4. 2021 Toyota Venza Key Fob Battery Replacement: 步骤 4 中的图像 1,3 2021 Toyota Venza Key Fob Battery Replacement: 步骤 4 中的图像 2,3 2021 Toyota Venza Key Fob Battery Replacement: 步骤 4 中的图像 3,3
    • If that doesn't work twist the key slightly and open up the plastic case.
  5. 2021 Toyota Venza Key Fob Battery Replacement: 步骤 5 中的图像 1,2 2021 Toyota Venza Key Fob Battery Replacement: 步骤 5 中的图像 2,2
    • Gently remove the old battery.
  6. 2021 Toyota Venza Key Fob Battery Replacement: 步骤 6 中的图像 1,2 2021 Toyota Venza Key Fob Battery Replacement: 步骤 6 中的图像 2,2
    • Insert a new CR2450 lithium cell battery.
  7. 2021 Toyota Venza Key Fob Battery Replacement: 步骤 7 中的图像 1,2 2021 Toyota Venza Key Fob Battery Replacement: 步骤 7 中的图像 2,2
    • Replace the back case.
    • Press the two halves together and snap it shut.
  8. 2021 Toyota Venza Key Fob Battery Replacement: 步骤 8 中的图像 1,3 2021 Toyota Venza Key Fob Battery Replacement: 步骤 8 中的图像 2,3 2021 Toyota Venza Key Fob Battery Replacement: 步骤 8 中的图像 3,3
    • Insert the key back into the case.
    • You're done!
结论
Press on the controller, and if a red light is shown when pressed, battery replacement is a success.
To double-check, go to your Toyota Venza and press the unlock or lock button; if the car responds, the battery works perfectly fine.
MGaliciaDiaz
于03/05/24注册
157 声望
撰写一个指南
团队
CSU Los Angeles, Team 7-5, Grodsky Spring 2024 CSU Los Angeles, Team 7-5, Grodsky Spring 2024 的会员
CSULA-GRODSKY-S24S7G5
2 名成员
创作了1篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 7
过去 7 天: 31
过去 30 天: 76
总计 138
